Anson_K
So I've been using my EVGA Gtx 1070 for a week or two now. So I've noticed that the fans started spinning from 50 degree onwards AT IDEL, is this normal? But it is spinning at such a low rate (10 in msi afterburner) that i don't think it is even doing much. I hope there's a fix to this as it is pretty annoying to look at especially when my GPU is at idle and the fans are already spinning. My card usually idles at 50-55 degree.It would be nice if someone could help me with this :D
bob16314
- Ribbons : 761
Re: EVGA 1070 SC Fan Problem
2018/06/13 09:09:43
The EVGA GTX 1070 SC and other ACX 3.0 cooling cards have a 0dB fan feature where the fans won't spin at low GPU temperature unless overridden with software such as EVGA Precision or MSI Afterburner. You can use a predefined fan curve or create your own custom fan curve in Precision or Afterburner. Nothing is wrong.
2018/06/13 10:48:25
Normal idle clocks should be 139/405. Get your clocks down to normal idle clocks, and your fans should shutoff. Here are the top causes of why a GPU would run at full clocks at idle... #1 You're running multiple monitors. Fix: Enable mutil display power saver using nvidia inspector.#2 Your machine has a virus. Fix: Scan computer using malwarebytes.#3 One or more programs running in the background are using your GPU. Fix: Perform a clean boot of windows.#4 Power management mode inside the nvidia control panel is set to prefer maximum performance. Fix: Set power management mode to adaptive then reboot your computer.#5 Running a resolution of 2560x1440 @ 144Hz. Fix: Change refresh rate to 120Hz.#6 K-Boost is enabled inside Precision X. Fix: Disable K-Boost.#7 Shadowplay is enabled inside geforce experience. Fix: Disable shadowplay inside geforce experience OR completely uninstall geforce experience from your machine (highly recommended)
bob16314
- Ribbons : 761
2018/06/13 12:26:12
Sajin Normal idle clocks should be 139/405. Get your clocks down to normal idle clocks, and your fans should shutoff. Here are the top causes of why a GPU would run at full clocks at idle...
#1 You're running multiple monitors. Fix: Enable mutil display power saver using nvidia inspector. #2 Your machine has a virus. Fix: Scan computer using malwarebytes. #3 One or more programs running in the background are using your GPU. Fix: Perform a clean boot of windows. #4 Power management mode inside the nvidia control panel is set to prefer maximum performance. Fix: Set power management mode to adaptive then reboot your computer. #5 Running a resolution of 2560x1440 @ 144Hz. Fix: Change refresh rate to 120Hz. #6 K-Boost is enabled inside Precision X. Fix: Disable K-Boost. #7 Shadowplay is enabled inside geforce experience. Fix: Disable shadowplay inside geforce experience OR completely uninstall geforce experience from your machine (highly recommended)
But, the question was about fan speed, not clock speed..Fan speed is based on temp, not based on clock speed, as you know..However, we all know that clock speed affects temps..But at 54C, the fan may kick in and run in low-rpm mode. If a 3D app is detected (Browser, Precision, whatever), the clock speed will ramp up. Nothing is wrong.
2018/06/13 12:27:17
Except he said his pc was idle, and his picture clearly shows he isn't running a custom fan curve, and he said he is annoyed by the fans running while idle.
post edited by Sajin - 2018/06/13 12:37:37
bob16314
- Ribbons : 761
2018/06/13 12:51:56
Sajin Except he said his pc was idle, and his picture clearly shows he isn't running a custom fan curve, and he said he is annoyed by the fans running while idle.
I know..'User defined' fan control is not enabled in the pic, or 'Fan Speed (%)' would be outlined red..Only GPU temp dictates fan speed..Clicking the gear icon to the left of 'Fan Speed (%)' switches fan control.
Todub
2018/06/13 23:34:06
Mine seems to be having some noise wobble. No interference from the nzxt cam software. I just leave it with stock EVGA drivers.
2018/06/13 23:59:23
Todub Mine seems to be having some noise wobble. No interference from the nzxt cam software. I just leave it with stock EVGA drivers.
You should try the bearing trick.
Todub
2018/06/14 00:12:56
This sounds a bit silly, but I guess it's worth a shot. The fans aren't loud by any means, but there is a bit of strange noise. I expected to be quieter. Though, makes sense that bearing could be causing this misalignment noise. I'll get back to this and might even make a video if this fixes the issue.
