EK Releases Classic Lineup Water Cooling Kits
  • Ribbons : 84
2019/07/18 09:28:45 (permalink)
https://www.techpowerup.com/257497/ek-releases-classic-lineup-water-cooling-kits
EK-KIT Classic products are value-oriented, RGB liquid cooling kits with low noise emissions that offer efficient cooling of any mainstream Intel or AMD CPU on the market. Ready to be expanded with a GPU water block, some of the new kit models also open up the door for overclocking. Designed with case compatibility in mind, these kits are a great way to enter the world of custom liquid cooling with easy installation.
They contain everything you need to assemble your first custom liquid cooling loop. You don't have to worry about compatibility issues, missing something, being nervous about the right amount of fittings or tube length. The newly released Classic kits are available in four different setups - S240, S360, P240, P360. They vary by radiator size and thickness, as well as number of fans. The rest of the components are shared across all of the kits.
These are good looking kits but the prices are reflective of the very high quality.
0 Replies Related Threads
