EK Launches their Next-Gen Velocity CPU water blocks
  • Ribbons : 84
2018/09/18 22:50:30 (permalink)
https://www.guru3d.com/news-story/ek-launches-their-next-gen-velocity-cpu-water-blocks.html
EK Water Blocks is proud to introduce the new generation of high-performance water blocks for popular AMD and Intel CPU sockets, the EK-Velocity. The new CPU water block will be available in a total of 14 versions featuring intricate RGB lit models, and down to simple minimalistic bare copper cold plate versions as well. The EK RGB logo are compatible with all popular RGB sync technologies from all major motherboard manufacturers. EK has always been known for good quality.
Supported Intel Sockets are:
  • LGA 1155
  • LGA 1156
  • LGA 1150
  • LGA 1151
  • LGA 2011
  • LGA 2011-3
  • LGA 2066
Supported AMD Sockets are:
  • AM4
8 Replies Related Threads
    Vlada011
    • Ribbons : 11
    Re: EK Launches their Next-Gen Velocity CPU water blocks 2018/09/19 02:36:38 (permalink)
    They are amazing... first two are killers...
    No way to pay almost 200 euro for Monoblock...
    EK Velocity Full Nickel RGB
    EK Velocity Acetal + Nickel RGB
    EK Velocity Nickel + Plexy RGB
    So hard to decide, so hard to choose.
    But first and second will fit so nice on some EVGA Z390 motherboard.
    Last and first fit perfectly with EVGA Hydro Copper.
    I'm so glad because I invest in watercooling, I'm sad because I have less for GPU and
    I don't know what to do, but could not calm until I try watercooling and I hope stay forever.
    http://www.evga.com
    http://www.intel.com
    http://www.nvidia.com
    https://watercool.de
    http://www.lian-li.com
    gutcheck
    • Ribbons : 9
    Re: EK Launches their Next-Gen Velocity CPU water blocks 2018/09/19 07:32:58 (permalink)
    Looks like I may be throwing a new block on that 9900k.
    3900X 4.5 GHZ on an Asus Hero
    32 GB 3600 MHZ Corsair RGB Pro DDR4 RAM
    1 EVGA 3090 XC3 soon to be Watercooled
    2 2GB Corsair MP600's
    HX1000 with custom sleaving
    • Ribbons : 122
    Re: EK Launches their Next-Gen Velocity CPU water blocks 2018/09/19 08:21:03 (permalink)
    I like my EK blocks.  These look nice just wish actual improvements were highlighted beyond the visual
    If I find some hard numbers of the improvements I'll share them in this thread
    GTXJackBauer
    • Ribbons : 48
    Re: EK Launches their Next-Gen Velocity CPU water blocks 2018/09/19 08:31:19 (permalink)
    I like that black and red velocity block. My only issue is being able to fit the big 1/2 x 3/4 bitspower fittings on them.  The threaded ports look too close for comfort.  The Swiftech XL block I currently use has the ports on each side with more than enough room.
    LMD3DNZM9LGK8GJ
    Vlada011
    • Ribbons : 11
    Re: EK Launches their Next-Gen Velocity CPU water blocks 2018/09/19 10:19:29 (permalink)
    GTXJackBauer
    That's not red, that's RGB, I think and EK logo shine on some versions.
    Why not, 1/2" 3/4" (13/19mm).... You install two 30 angle or 40 angle adapter and than fittings on them.
    Or this 2 of this on CPU Block...
    Why you like so thick fittings, thickest for me is 13/10mm, but I would not have nothing against 8/10mm.
    Only they are more rear to find.
    http://www.evga.com
    gutcheck
    • Ribbons : 9
    Re: EK Launches their Next-Gen Velocity CPU water blocks 2018/09/19 11:35:56 (permalink)
    Are the holes in these blocks in the exact same place as the supremacy blocks?
    knightsilver
    • Ribbons : 14
    Re: EK Launches their Next-Gen Velocity CPU water blocks 2018/09/19 15:06:43 (permalink)
    I'll take the Copper block Alex, no RGB for me...
    Vlada011
    • Ribbons : 11
    Re: EK Launches their Next-Gen Velocity CPU water blocks 2018/09/19 18:47:23 (permalink)
    knightsilver
    Why Copper, you have Nicker + Acetal Non RGB...
    Full Nickel Version shine only EK Logo I think. You could change on White example.
    No matter on model, if I decide Full Nickel I will think did I choose good or if I decide Acetal+Nickel I would think about shine Silver...
    Because of that I must see in RIGs to confirm...
    You see full Nickel is only Logo...  You can always disable RGB cable.
    http://www.evga.com
