Re: Dual Monitor Issue - Low FPS with 3080 FTW3
2021/11/27 22:42:23
Capt_Caveman
I'm stumped. Having an issue with running two monitors off a 3080 FTW3 and not being able to get frame rates above 80 fps while gaming on either monitor. Monitor 1 is an Alienware AW34518DW 120hz and the other is a LG 27GP850-B 180hz. I have enable/disabled gsync, set the LG to 120hz, switched the Alienware to hdmi from dp, switched which monitor is the primary monitor and put both to scale via GPU(this seemed to fix stuttering). Any thoughts? Used to have no issues with my old 1080ti FTW3 running two monitors via dvi-d and dp and was running a GT 710 to an old monitor with the 3080 FTW3 connected to the Alienware before Nvidia stopped supporting the GT 710 so I got the LG. Not sure what else I should try.
First question, does this occur with just a single monitor connected? When you are gaming, what are the clocks and load you are seeing? Is the GPU being utilized properly? Are you using any program at all that can cap frame rates/frame rate limiter etc?
EVGA X99 FTWK / i7 6850K 4.5ghz / RTX 3080Ti FTW Ultra / 32GB Corsair LPX 3200mhz / Samsung 850Pro 256GB / Corsair AX1200 / Window 10 Pro
Fire Strike 24,163
Fire Strike Extreme 14,452
Fire Strike Ultra 7,711
Time Spy 10,357
