Cooler Master Shows Off Cooling X, a Unique Prebuilt with Whole-body Liquid Cooling
  • Ribbons : 86
2023/01/14 01:50:06 (permalink)
https://www.techpowerup.com/303532/cooler-master-shows-off-cooling-x-a-unique-prebuilt-with-whole-body-liquid-cooling
Cooler Master at the 2023 International CES showed off the Cooling X, a patent-pending unique desktop PC architecture by the company where the liquid cooling of the CPU and GPU isn't confined to a couple of closed loop AIOs, but rather a giant liquid-cooling loop that even involves the side-panels of the case itself, that double up as additional heat-dissipation surfaces. Notice how some compact fanless cases use extruded-aluminium body panels that double up as heatsinks, to cool the hot components? The Cooling X re-imagines this, where instead of dissipating heat from a heatpipe, the extruded-aluminium body panels have coolant channels, so some of the heat from the liquid-cooling loop is dissipated. These panels supplement a conventional liquid-cooling radiator that's located along the rear panel, which has active ventilation. The liquid-cooling loop cools the processor and GPU.
For its compact dimensions of just 266 mm x 149 mm x 371 mm (LxWxH), the Cooling X prebuilt packs some mighty high-end hardware—an AMD Ryzen 9 5950X 16-core processor, and a Radeon RX 6800 XT GPU up to 64 GB of dual-channel DDR4-3200 memory, two 2 TB M.2 NVMe SSDs, and a homebrew 850 W 80 Plus Gold SFX power supply. For now Cooling X is just a codename, and Cooler Master intends to take this concept forward with high-performance gaming/creator prebuilt desktops sold under its own marquee.
A very interesting concept.
1 Reply Related Threads
    Chaos_21
    • Ribbons : 10
    Re: Cooler Master Shows Off Cooling X, a Unique Prebuilt with Whole-body Liquid Cooling 2023/01/14 08:40:28 (permalink)
    This looks like an interesting start to many new case configurations.
    ASUS TUF Gaming Z690-Intel Core i9-12900K- EVGA 360 CLC Cooler-Corsair Vengeance 4 x 16GB 3200mhz-2TB  Solidigm P41 Plus M.2 SSD--Three 1TB 970 EVO SSD's-EVGA GeForce RTX 3080 XC3 ULTRA-Corsair HX1000i-Windows 11 64bit-Corsair iCUE 5000X RGB Case.
     Steam     Twitter: https://twitter.com/Chaos_21
     Use my associate code: JBGVM12HDYDJPIM to get 5%-10% discount on EVGA purchases.
