Connecting the EVGA NU Audio Pro 7.1, 712-P1-AN21-KR, 7.1 Surround to an AV Receiver
baneling2
2020/02/20 06:20:46 (permalink)
Hi all, I have a win10 PC that i'm using to watch movies.  I use plex with that.  I have the PC connected to my Denon 7.1 AV receiver.  If I buy this audio card, how do I connect it to my receiver to get the 7.1 audio?  Right now I have my PC connected to the receiver using an HDMI cable.  But this card doesn't have an HDMI port.  If I use the SPDIF port, will not that limit me to only 5.1?
jvpix.com
3 Replies Related Threads
    playboyer
    Re: Connecting the EVGA NU Audio Pro 7.1, 712-P1-AN21-KR, 7.1 Surround to an AV Receiver 2020/02/25 20:58:16 (permalink)
    You are getting sound as good quality as that receiver via HDMI since the receiver is doing all the processing.   You do not need a sound card for that and getting a sound card only to connect it via optical out is only a down grade due to the limitation of optical.
    baneling2
    Re: Connecting the EVGA NU Audio Pro 7.1, 712-P1-AN21-KR, 7.1 Surround to an AV Receiver 2020/02/26 05:26:24 (permalink)
    so you're saying the receiver is creating the sound, not the PC?
    jvpix.com
    EVGA_Lee
    Moderator
    • Ribbons : 14
    Re: Connecting the EVGA NU Audio Pro 7.1, 712-P1-AN21-KR, 7.1 Surround to an AV Receiver 2020/02/26 16:34:44 (permalink)
    baneling2
    To be more technical, the source audio "creates" the sound; the receiver decodes an audio signal passed to it from the PC, and converts it to an analog signal before passing it to your speakers. There are some receivers that have analog inputs, but there aren't many left these days.
    As such, you're discussing two different digital output options in HDMI and S/PDIF.  The audio card would be more relevant if the DAC on the card was used prior to the signal going out to the receiver, but it isn't.  As such, the receiver will decode the audio from the incoming digital signal and convert it to go to your speakers.  HDMI offers up to 7.1 audio, whereas S/PDIF only has enough bandwidth to support compressed 5.1 channel audio.  By and large, HDMI is going to be the better option in most cases for your audio situation.
