Re: Case FAN 3PIN vs 4PIN
2017/03/24 22:22:21
☄ Helpfulby NPNiles 2017/03/26 10:43:46
The 4th wire is PWM or Pulse Width Modulation and it does a better job at reducing and controlling fan speed than reducing the voltage for a 3 pin fan.
There is no disadvantage, and depending on the board you can change certain fan headers to how they control the fan. Either by PWM, or voltage, but some can't control via voltage, so you would be at full speed. PWM fans are typically more expensive, but can work better at slower speeds.
Case - Phanteks Enthoo Evolv XMobo - EVGA X570 FTWCPU - AMD Ryzen 9 5900XRAM - 32GB Trident Z Royal 3600MHz 14-14-14-34GPU - EVGA RTX 3080 Ti FTW3 Ultra GamingPSU - Seasonic Prime TX-1000Heatkiller IV CPU Waterblock / Heatkiller V GPU WaterblockHeatkiller V EBC Active Backplate / Two Heatkiller Rad 360 L Six Noctua NF-A12x25 / Heatkiller D5 Pump
