Cannot adjust fan speed
Seann.v91
2024/09/11 22:39:33 (permalink)
Hello all,
I have a 3080TI sitting on a Z690 Dark Kingpin that i’ve been using and initially the build was quiet but after a few days or so the GPU fans have been spinning at (what sounds like) full capacity just on idle - making the room sound like an MDF room lol.
After some research on this board. I have tried X1 to adjust the fan speed but I noticed that X1 only detects 1 of the GPU fans instead of all 3. I also tried previous versions of X1 but the same issue persists. So I tried Afterburner but the GPU fans don’t sync. I would continue to troubleshoot here and there for over a year especially with the BIOS settings and t-attempted under-volting but was never able to find a resolution
Saw a few posts where an RMA was suggested but was wanting to post this first in hopes to see if anyone is able to help me find a solution to get the fan speeds down
Thanks guys
All things serve the beam
1 Reply Related Threads
    Nozler
    Re: Cannot adjust fan speed 2024/09/26 04:15:34 (permalink)
    In the bottom right hand corner of AB you can make two fan profiles ,you have to unlink them in order to do this then you'll be able to control two fans on one profile then one on another just make the fan curves the same and save it.  You tube might have a video on this procedure. Good luck
    heatware
