Re: CLC 280/Flow Control Wont Display CPU Temp
2018/03/05 07:25:26
I had the same problem and fixed it by switching the header that the pump plugs into from DC to PWM. Also make sure the header is set to run at full speed with no fan curves.
Might not fix anything though, the software needs a lot of work.
