CLC 280 keeps losing USB connection to system.
jmaster299
2017/10/12 00:57:43 (permalink)
As the title says, my CLC 280 keeps losing it's connection to my system. I can hear the Windows sound notification, like a device being unplugged, and the Flow Control software will stop reporting any information. I'm assuming this is a hardware issue, because the software simply not working correctly would not cause my system to behave as if a cable has been unplugged. I've double check all my connections, and everything is fine. It's connected to a Gigabyte Z370 Gaming 7. I have no issues with anything else, just my CLC 280.
Cooler Master HAF X | i7 2600K@4.6GHz | Corsair A70 | ASUS p8z68-v Pro Gen3 | 16GB Corsair Vengeance LP DDR3@1600MHz | EVGA GTX 1080 FTW2 | Samsung EVO 850 500GB | WD Black 2TB | AOC G2460PF 144Hz
Previously owned EVGA GTX 1070 FTW, EVGA 970 SC, EVGA 670 FTW Sig2, EVGA 570 HD, EVGA 8800 GT and EVGA Killer Xeno Pro.
EVGA CLC 280 and EVGA Supernova 750w G3 purchased and waiting for install in new build.
Look at my join date and ownership history before you try telling me I'm not a real fan of EVGA. I even bought the damn hat.
4 Replies Related Threads
    • Ribbons : 145
    Re: CLC 280 keeps losing USB connection to system. 2017/10/12 08:31:05 (permalink)
    Try a different usb port.
    MSim
    • Ribbons : 30
    Re: CLC 280 keeps losing USB connection to system. 2017/10/12 08:48:14 (permalink)
    In your bios make sure the CPU fan is set to PWN or constant 100%.
    ٩(̾●̮̮̃̾•̃̾)۶Intel i7-7700k •̪̀●Corsair H100i V2 •̪̀●ASUS Z270 HERO •̪̀●G.SKILL DDR4 3200 2x16GB •̪̀●EVGA 750W P2 •̪̀●Windows10 Pro 64-bit •̪̀●EVGA GTX1060 •̪̀●Samsung 960 EVO m.2 1TB •̪̀●Corsair 450D •̪̀●ASUS 24" VE248H •̪̀●Corsair K70 Lux RGB •̪̀●Logitech G500s •̪̀●Sound BlasterX AE-5٩(̾●̮̮̃̾•̃̾)۶ Affiliate Code: G8N4K5CUFY
    jmaster299
    Re: CLC 280 keeps losing USB connection to system. 2017/10/12 16:14:11 (permalink)
    MSim
    Had does this affect operation? Will Flow Control still vary pump/fan speed on it's own? I'm having other issues with it too. Flow Control refuses to report fan speed, just a blank field. I've tried multiple different headers. It also refuses to maintain manual fan settings. When I disable the auto fan control to disable the curves, and manually move the fan or pump speed slider, it's always a short while before Flow Control simply moves them to wherever it wants.
    As for the system fan settings, I think that's part of my issue with it losing it's USB connection. When I uninstalled the Gigabyte Flow Control software, which is just the desktop version of what I have in the BIOS, the disconnection issues decreased. Not completely, but it's not constantly losing it's connection now. But still drops randomly. I have tried switching to the other USB 2.0 header, same problem. Though when I switch those headers my USB 2.0 connections at the front of my case, using the other header, never have any problems.
    djsimonitaly
    Re: CLC 280 keeps losing USB connection to system. 2017/10/13 11:07:31 (permalink)
    I have an Asus Z270E, and I connected the fan pin to the AiO header, in the Bios I've enebled to monitor (display) the fan speed but the speed control.
    If you set the motherboard to control your fans speed, then Flow control won't be able to control them through the Usb connection.
    I hope this can help even if my motherboard is different.
    Try to uninstall the Gigabyte Control Software and see if helps.
    THERMALTAKE VIEW 31 / i7 7700K Delided @ 5Ghz / EVGA CLC 280 / Asus Strix Z270E / Corsair Vengeance LPX 16gb DDR4@3200Mhz / EVGA GTX 1080 FTW2 / SAMSUNG 840 PRO 256GB, 850 EVO 500GB / WD CAVIAR BLACK 4TB / Acer Predator XB1 XB271HU abmiprz
