Join us now!
Username
Password
Verification
Stay logged in
Login
Forgot Your Password?
Forgot your Username?
Welcome,
User Control Panel
Log out
NEWS
News & Notice
EVGA News
Press Release
Product Updates
EVGA Z Series Keyboards
EVGA X Series Gaming Mice
EVGA Z590 Motherboards
EVGA GeForce RTX 3060 12GB
EVGA XR1 Capture Device
EVGA RTX 3060 Ti
EVGA BP Power Supply Series
EVGA NU Audio Pro
EVGA FROSTBITE 2
EVGA RTX 30 SERIES
Awards
All Awards
Graphics
Motherboards
Power Supplies
Mice
Case
Technology
EVGA iCX3
EVGA Motherboards
EVGA Power Supply
EVGA NU Audio
EVGA HYBRID Coolers
EVGA PowerLink
EVGA Precision X1
EVGA ELEET X1
CONCEPT
Design Concept
Graphics Cards
Motherboards
Power Supplies
Cooling
Case
Gaming Gear
Audio Card
PRODUCTS
Graphics
All Graphics
GeForce RTX 3090
GeForce RTX 3080
GeForce RTX 3070
GeForce RTX 3060 Ti
GeForce GTX 1650 Super
GeForce GT 1030
GeForce 30 Series ▶
GeForce RTX 3090
GeForce RTX 3080
GeForce RTX 3070
GeForce RTX 3060 Ti
GeForce 16 Series ▶
GeForce 700 Series ▶
GeForce GT 710
GeForce 200 Series ▶
GeForce GF 210
GeForce 10 Series ▶
GeForce GT 1030
PowerLink
SLI Bridges
Graphics Card Awards
Motherboards
All Motherboards
Intel C622 Series
Intel X299 Series
Intel Z490 Series
Motherboard Awards
Power Supplies
All Power Supplies
SFX Power Supplies
Cable Set
Cable
1600 Watts
1300 Watts
1200 Watts
1000 Watts
850 Watts
750 Watts
710 Watts
700 Watts
650 Watts
610 Watts
600 Watts
550 Watts
510 Watts
500 Watts
460 Watts
450 Watts
400 Watts
Power Supply Awards
Gaming Keyboards
Z20 Series
Z15 Series
Gaming Mice
X20 Series
X17 Series
X10 Series
X5 Series
Capture Device
XR1
Audio
Audio Card
Cooling
CPU Closed Loop Cooler
GPU HYBRID Cooler
Thermal Grease
Featured
DIY Configurator
Featured Products
Featured Bundles
Overclocking Software
EVGA Precision X1
Cases
DG-7
Case Awards
Other Products
Accessories
B-Stock
EVGA Gear
Where To Buy
Browse All Products
All Awards
SERVICE
Product Info.
EVGA Software
Drivers and BIOS
Power Meter
Product Manuals
Product Specs
CPU and Memory Support
EVGA FAQ
Service
Product Registration
Invoice Upload
Support Tickets
Submit Warranty Claim
Dealer RMA
Open RMAs
Order History
RMA History
Warranty Check
Rebate Tracking
Contact Us
Contact Info
Contact Tech Support
Complaints and Suggestions
EVGA Support Team
Rate Our Service
Terms & Conditions
EVGA Warranty
EVGA Extended Warranty
How To RMA
EVGA Advanced RMA
EVGA Step-Up
Dealer RMA Terms & Conditions
VIDEOS
COMMUNITY
Forums
Forum Home
Graphics Cards
Motherboards
Power Supplies
NU Audio Series
CLC & Hybrid Coolers
Gaming & Gaming News
Computer Hardware & Software
Distributed Computing
EVGA Marketplace
Mods Rigs
Top Rated Systems
Build Your Rig
Public Showroom
Win Prizes
Community Portal
Current Promotions
EVGA on Social
EVGA Step Up Program
EVGA Bucks
Folding@EVGA
Newsletters
EVGA Weekly Livestream
EVGA Associates Program
EVGA ELITE Membership
Streamer Central
About
About EVGA
Careers
Press Releases
MY EVGA
My EVGA
My EVGA
My Profile
My Products
My Data
View Software Bundles
My Open RMAs
My Order History
My Notifies
EVGA Rewards
Elite Membership
ELITE Home
Associates Program
Associates Home
Service
Contact Info
Check My Tickets
Rate Our Service
Forums
Posts
Latest Posts
Active Posts
Recently Visited
Search Results
View More
Blog
Recent Blog Posts
View More
Photos
Recent Photos
My Favorites
View More
Photo Galleries
PMs
Unread PMs
Inbox
Send New PM
View More
Page Extras
Menu
Forum Themes
EVGA_CLASSIC_V2
EVGA_LIGHT
Mobile
All Forums
[Other EVGA Products]
All Other EVGA Products
CLC 280: Fans Above 1000 at Idle Temps of 35-38C Despite Flow Control Adjustments
Mark Thread Unread
Flat Reading Mode
Hot!
Post
Essentials Only
Full Version
BuzzRobot
Reward points : 0
2017/09/26 09:57:12
Status:
offline
Ribbons : 0
2017/09/26 10:51:41
permalink
Two days in with a CLC 280 here. Using an i7-7700k that idles at 35-38c stock on an MSI board with the pump connected to the pump header and the fans to a sysfan via a splitter. Using the latest Flow Control update.
Frankly, I'm very confused about how to control fan speeds and reduce noise.
(Short version of all this is no matter the changes made with Flow Control, fan speeds are always at or just above 50% except when CPU temps hit 60C, when they max out.)
1. Specs say fan speed range is 600-2200 rpms. Lowest speed I've seen here is 960, accomplished by clicking the green "Auto" on Flow Control to white (presumably this disables "Auto" -- whatever that is -- but since there are NO instructions or help screens it isn't at all clear what that does) and then manually pulling the fan slider all the way down.
2. Fixed minimum fan speed in Flow Control is 25%. Twenty-five percent of 2200 is 550. I've tried setting both CPU and coolant fan curves with all points between the fixed min and max to 25% at 40C. After a reboot, the results: At the idle of 35-38C, fan speed varies from 1060-1200. Since both CPU and coolant temps are below 40C, why arent the fans at 550 RPMs?
If I stress the CPU using that flat fan curve, fan speed does spike to 1980 (not 2200) at 60C. Speed drops to 1060-1080 after terminating the stress program and CPU temp returns to 35-38C.
At the moment Flow Control is showing CPU at 35C, coolant at 34C, pump speed at 2910, and Fan Speed at 1080. "Auto" is green and both fan curves are set to 27% at 40C. 27% of 2200 is 594.
3. Fan noise increases dramatically as soon as I close an open instance of Flow Control. HWMonitor shows speed jumps to 1340-1500.
4. Also unclear on how to create/edit/delete profiles. Is the intent that the "Apply" button goes white when a change is made, and clicking that white button will save the changes in a profile? If so, which profile? All profile numbers here are currently dimmed out. If I left click or right click on a profile number, it goes white.
The "Apply" button is usually dimmed out, sometimes it's white of its own volition, and sometimes, but not always, it changes to white after I adjust something.
Also unclear how to select one of multiple profiles and if that selection survives a restart.
5. Disabling the CPU fan curve enables the coolant curve, and vice versa. What if I want to disable both and control fans via BIOS? (That would be with the pump fan set to PWM here. Setting it to DC or AUTO drop the speed to 0 and produce a "NO CPU FAN!" message on reboot.)
7. As reported elsewhere, the "LED Temp" option is not permanent and clicking the "OK" button appears to do nothing.
8. If Flow Control's "Run at StartUp" option is enabled and I open a window of the running instance via the Task Bar and then close it, the entire app terminates completely and fan speed jumps.
post edited by BuzzRobot -
2017/09/26 11:33:18
Related Threads
sommersc
Reward points : 0
2016/03/08 00:37:32
Status:
offline
Ribbons : 0
Re: CLC 280: Fans Above 1000 at Idle Temps of 35-38C Despite Flow Control Adjustments
2017/09/27 12:37:31
permalink
Sounds like it isn't being saved to the firmware. Right-click one of the numbered boxes and save the profile.
#5 - plug the fans into your mobo then and run it off BIOS; the pump needs to go into PUMP or CPUFAN and be at 100% in BIOS
It sounds like you have something set in your BIOS that is messing with flow control, I would investigate that too.
BuzzRobot
Reward points : 0
2017/09/26 09:57:12
Status:
offline
Ribbons : 0
2017/09/27 12:57:27
permalink
I’m confused about how to create a profile. Is it only the fan curve? Does it include the position of the Pump and Fan sliders? Which takes precedence, the curve or the sliders?
How is a fan curve applied? By saving a profile and reloading?
Does a profile include LED, update options, etc?
Does right clicking save a profile? Is a profile loaded automatically on startup? If so, which one?
What should be set to 100% in BIOS? Fan speed? BIOS offers PWM, DC, and AUTO selections with “Smart Fan Control” option offered for any of those three choices.
Pump speed needs to be kept at 100% if controlled via BIOS although Flow Control allows it reduced well below 100%? (I’ve seen recommendations to use the sliders to reduce fan and pump speed to the minimum to reduce noise. The fans, like all fans, are obtrusively loud over 1000 rpm.)
The board has CPUFan and PUMP headers. I’m currently using PUMP.
2017/09/27 13:04:06
sommersc
Reward points : 0
2016/03/08 00:37:32
Status:
offline
Ribbons : 0
2017/09/27 13:05:33
permalink
We'll probably need someone from EVGA to directly comment on when exactly the firmware is updated (I think it's after saving a profile).
The profile saves: fan, pump, color, etc. If you set a fan curve and keep it on auto, then it will use that. If you take it off auto, then it will use whatever the slider is at.
Yep, right-click saves to a slot. AFAIK, this also saves to firmware, so you could technically delete flow control at this point (assuming everything else is as you want it - LED etc). Yes, whatever profile is currently selected is loaded at startup.
Pump should be set @ 100% in BIOS. Do NOT use any kind of smart control there. If you're using fans with the y-splitter, then disable any kind of curves you have there too.
If that still doesn't work, then try using CPUFan and follow the above (100%, no smart control).
phoenix136
Reward points : 0
2008/11/07 14:43:28
Status:
offline
Ribbons : 1
2017/09/27 19:48:12
permalink
The fan curve percent is not the percent of the max fan speed. In Flow Control this % is the duty cycle of the PWM signal. I tested it with one of my fans because I was having similar frustrations:
You'll notice at 25% duty cycle the fan will spin at around 1000RPM. Why does Flow Control limit the lowest PWM signal to 25%? I have no idea. Best solution is to control via some other method, probably Mobo PWM fan headers.
Affiliate Code: NAIF49SD85
Joosen EVGA
Reward points : 0
2020/11/12 11:20:26
Status:
offline
Ribbons : 0
2020/12/25 13:43:10
permalink
Solution.
Joosen EVGA
Reward points : 0
2020/11/12 11:20:26
Status:
offline
Ribbons : 0
2020/12/25 14:02:22
permalink
Replace the horribly noisy EVGA fans to cheap, but reliable and efficient Arctic PWM PST fans. They are interconnectable and even with 700 rpm less max speed (1800 vs 2500) I regained the same 5000Mhz overclock with the EVGA OC Robot in my BIOS. Or if you have deep pockets, go with Noctua and their Y-splitters that come with the product. Just anything interconnectable will do.
Connect fans together and then connect the last fan to the motherboard anywhere you want. I used CPUFAN2. Then you will have complete control via BIOS over the originally horrendous piece of hardware and software you have bought.
The pump I have connected to CPUFAN1, since I have no pump header on my EVGA FTW WIFI Z490 mobo. Put that to 100% in the BIOS. I don't know if it's of any help, because I still don't have the "apply" button active in Flow Control. I had it active at one time but I don't remember or get what were the circumstances that enabled it or does it help.
The Flow Control is a piece of crap for software, and luckily you don't have to use it anymore for the fans if you do what I tell you, but I think the pump will be running on the speed you have set it on even after reboot.
Because the AIO is warranted, I have it on max setting 24/7 since the noise is just about the same on all settings and does not bother. Basically you will need the app only if you want to change the color and behaviour of the RGB EVGA-logo on the pump itself.
I have tried the aforementioned EVGA fans as case fans after removing them from the AIO, but there's just something wrong with the motors or the bearings - or likely: both.
The noise is just unacceptable at all speeds.
You will just have to throw them to garbage.
It is a shame, but this is the only way to live with an EVGA AIO. Replace the fans and connect them to the mobo, use the BIOS to control them, and then, and only then you will have silence and peace. You will just have to accept that in it's original state, the EVGA AIO is just crap!
The Arctic P12 or P14 PWM PST fans are optimized for radiators and sell for just about 7$ a piece. They are test winners, warranted for 5 or more years, powerful and silent and come with integrated Y-splitters in each fan. I can really recommend them! I have the 360 AIO and I only had to spend like twenty euros to do this complete overhaul, and I think this is a better choice than to try getting your money back. I think you won't get it back, since the AIO kinda works with the original setup. It's just unusable because of the noise..
Spend the 20 and your good to go with no regrets!
post edited by Joosen EVGA -
2020/12/25 14:50:58
Jump to
Jump to
[EVGA Graphics Cards]
- - - - EVGA GeForce RTX 30 Series
- - - - EVGA GeForce RTX 20 & GTX 16 Series
- - - - EVGA GeForce GTX 10 Series
- - - - All Other EVGA Graphics Cards
- - - - EVGA Precision X1
[EVGA Motherboards]
- - - - EVGA Z590 Series
- - - - EVGA X299 Series & SR-3 DARK
- - - - EVGA Z490 Series
- - - - EVGA Z390 Series
- - - - All Other EVGA Motherboards
[EVGA Peripherals]
- - - - EVGA Gaming Keyboards
- - - - EVGA Gaming Mice
[Capture Devices]
- - - - EVGA XR1 Capture Device
- - - - EVGA Power Supplies
- - - - EVGA NU Audio Series
- - - - EVGA CLC & HYBRID Coolers
[General Forum]
- - - - General Discussion
- - - - EVGA Step-Up Program
[Computer Hardware & Software]
- - - - Computer Industry News
- - - - Overclocking Lab
- - - - MODS RIGS
- - - - Hardware
- - - - Software
[EVGA Marketplace]
- - - - For Sale or Trade
- - - - WTB and Price Checks
- - - - Hot Deals
Back to Mobile
