Re: CLC 280 - Can't control FAN speed
2020/12/24 10:22:44
Dear all EVGA CLC users,
I come to here and reply this post because of I'm one of the EVGA fans. I search around for many many posts and solutions, finally solved my problem by changing all the radiator fans to Noctua NF-A14 PWM:
So, I would say the original EVGA radiator fans QC have to be improved. Don't just asking people to go for the RMA, really feel sad as a EVGA fan. Take the recent products of Asus ROG RYUJIN as example, they use Noctua fans as well. I'm not saying EVGA must use Noctua fan, but the originally EVGA CLC radiator fans really got the problem. I guess EVGA should know about it too.
If you are encountering any problem on the radiator fans, such as not spinning, no FAN SPEED showing on the EVGA flow control software...etc, then stopping searching and testing around, just go to buy and replace the radiator fans, Everything will be fine.
Cheers!
