CLC 240 radiator bad temps with 3800x and 5600x (used to work fine for 2 years)
pixelcowboy
2020/12/10 09:34:48 (permalink)
I have an EVGA CLC 240mm cooler that was giving me decent performance with a 2600x. I upgraded to a 3800x, and now a 5600x, and I've getting really hot temperatures. I'm idling around 49-55 celcius, 84c on Cinebench, Prime 95 95c (small FFT), and between 75-85 in gaming (I do have an XC3 3080 that runs fairly hot dumping air into the case, at around 79C, but that wouldn't affect cpu only stress tests). I have a S100 with reasonable good airflow (3 front intake fans, 2 arctic bionic fans push for the aio exhaust, and another fan exhaust at the back, although my exhaust is a bit restricted with just around one inch of clearance at the top (pc is inside a cabinet, but front is open for airflow).
I do not seen any indication of the pump failing, but I can't really hear it either, and I've repasted multiple times without improvement. Any idea on what to try? Also, how do I get support? I think I threw away the box so not sure where to get the serial to submit a support ticket.
6 Replies Related Threads
    • Ribbons : 122
    Re: CLC 240 radiator bad temps with 3800x and 5600x (used to work fine for 2 years) 2020/12/10 13:26:47 (permalink)
    Did you register the CLC when you bought it ?
    Clean the radiator of any dust blocking air flow
    MB header setting should be 100% power
     FAQ-   How Do I Troubleshoot Issues with Flow Control For My CLC Cooler?
    pixelcowboy
    Re: CLC 240 radiator bad temps with 3800x and 5600x (used to work fine for 2 years) 2020/12/10 13:40:06 (permalink)
    I didn't register it when I bought it, is that an issue for warranty? Not much dust obstructing and the header is full power.
    Armons account
    Re: CLC 240 radiator bad temps with 3800x and 5600x (used to work fine for 2 years) 2021/04/28 22:08:26 (permalink)
    check for bent radiator fins, dust in the radiator, dust in the fans, fans not properly assembled and fan connections, make sure you didn't screw the AIO down on one side too much, make sure you didn't put too little or too much thermal compound on the CPU, etc.
    Rig specs #1: Rtx 3070 FE (on air), 5900x, 64gb crucial ballistix 3600mhz CL16 RGB Ram,  addlink 2tb nvme ssd, WD SN750 1tb nvme ssd, bitspower water cooling parts for cpu (tubing, block, rad, distro plate), ASUS B550 XE, corsair RM850x, Lian Li o11 dynamic
    Rig specs #2: EVGA GTX 970 SC (on air), 9700k, 32gb crucial ballistix 3200mhz CL16 RGB Ram, Seagate 2TB HDD, OCZ vertex 4 128gb SATA SSD, lian li Galahad 240mm AIO (For CPU), gigabyte Z390 M Gaming, corsair cx650M, Corsair "big boy case" Carbide Series Air 540
    Rig specs #3: 2x XFX Radeon HD 7870 ghost (on air in cross fire mode), Some AMD FX 8 core CPU, 32gb Gskill 1600mhz CL9 RAM, Inland 128gb SATA SSD, some old corsair AM3+ 240mm AIO (for CPU), ASUS Crosshair V Formula-Z, An old Coolermaster 1200watt 80+ Gold rated PSU, Phanteks Eclipse (PH-EC300PTG_BK)
    D3_GX
    Re: CLC 240 radiator bad temps with 3800x and 5600x (used to work fine for 2 years) 2021/04/29 19:29:10 (permalink)
    Try possibly remounting it for better mount pressure.
    Pigbutcher
    Re: CLC 240 radiator bad temps with 3800x and 5600x (used to work fine for 2 years) 2021/05/03 07:49:11 (permalink)
    Demont clc, repaste again(I have best thermals with paste on X over cpu) and be sure you mount it properly. I have Ryzen 9 5900x cooled by Air Noctua NH-D15s(1 fan version). On iddle temps jumps from 34 to 44°C, Cinebench R20-61°C, CB r23 - 65°C. True is I undervolt CPU with PBO2 using curve optimizer to nearly max negative offset. CPU runs faster and produce significaly les heat now. (Sorry for my poor english)
    Ryzen 9 5900x + Noctua NH-D15s
    Asus Strix B450-E gaming WI-FI
    32gb(4x8gb) RAM Patriot Viper 4400mhz CL19@ 3200mhz CL14 tunned
    Aorus RX 580 8GB(Nearly dead:()
    Samsung 970 Evo+ 250gb NVMe, Samsung 970 Evo 500gb NVMe, Samsung 860 500mb SATA,
    Be quiet Pure base 500
    Corsair AX 860W PSU
    pixelcowboy
    Re: CLC 240 radiator bad temps with 3800x and 5600x (used to work fine for 2 years) 2021/05/08 10:52:59 (permalink)
    Now I have a clc 280mm, idle is also between 37-44, and with PBO on and autOC (with curve optimizer, too) it still gets to around 80c full blast on Cinebench, but gaming more commonly 50-70c depending on the game and frame rate. Anyway, it just seems like this chips run hot because of the very small surface area, so I'm not worried about it.  At stock it runs much cooler of course, rarely breaking 60c. Maybe my 5600x just runs a bit hot, but it performs good.
