genghiskhanpl
Hey guys - burson op-amp v6 is available on massdropCheck audiophile section, or type "burson" search box. It's best way to upgrade our nu audio card :) Check it out - i got already v5i version but planning install v6 classic :) You can read about this in my review: https://forums.evga.com/R...m-Poland-m2916467.aspx
post edited by genghiskhanpl - 2019/03/09 10:39:39
i7 5960x @ 4500mhz, 32gigs 3200mhz ram, asus x99 deluxe II, asus 1080 GTX, EVGA Nu Audio
EvoLunatic
Re: Burson V6 op-amp on massdrop - best way to upgrade Nu Audio op-amp
2019/03/09 09:35:17
How do you like the V5i? Can you describe the change?
LordGTXTitan
2019/03/09 10:23:48
genghiskhanpl
2019/03/09 10:29:09
v5i vs factory amp - overall improvment, deeper bass, more details and way more musical v6 is even better, but dont fit the case, so you must remove cover with rgb lights
GGTV-Jon
- Ribbons : 19
2019/03/09 10:44:40
genghiskhanpl v5i vs factory amp - overall improvment, deeper bass, more details and way more musical v6 is even better, but dont fit the case, so you must remove cover with rgb lights
Might have to look into some spacers to raise the cover for V6 clearance I will have my NU next week, and hopefully have both a V6 Classic and Vivid for comparison by the end of the month
sovereign73811
2019/03/09 20:56:03
Hey nice! I was upset when that authorized retailer on Amazon cancelled my order about a month ago when I tried to buy the V6. Got myself two using your link of course. Thank you!!!!
genghiskhanpl
2019/03/09 23:25:33
sovereign73811 Hey nice! I was upset when that authorized retailer on Amazon cancelled my order about a month ago when I tried to buy the V6. Got myself two using your link of course. Thank you!!!!
Your welcome!
LordGTXTitan
2019/03/10 05:32:19
So when I am into music I should use the v5i ? Because I am playing also a lot computer games.
post edited by LordGTXTitan - 2019/03/10 06:48:07
GGTV-Jon
- Ribbons : 19
2019/03/10 10:28:52
LordGTXTitan So when I am into music I should use the v5i ? Because I am playing also a lot computer games.
Try them either way - find what sounds / works best for you Seems like too much work though to be swapping OP-Amps when going between music and games - unless you switched between the line out and headphone out
- Ribbons : 270
2019/05/26 22:29:10
It's all smoke and mirrors. All this audiophile stuff is simply a method of adding filters and altering the original recording to suite your preferences. Any purist should just leave it alone. It's a perfect sound reproduction with the most basic $5 hardware already available.
post edited by ty_ger07 - 2019/05/27 07:27:20
jonny80s
2019/11/11 18:44:25
Do the V6's actually fit with out dip 8 extensions on EVGA's Nu? I have an old Xonar Essence STX and ordered Muses02, V5i and V6 Vivid, the V6s don't fit without extensions because of the CAPS next to the op amps, not sure if the STX 2 has a better layout to allow their use. Currently using the Muses02 as the output opamps and one of the V5i's as the low pass filter. My headphones aren't the best, Denon 2000s (been looking to upgrade, now that the BD T1's are ~$700...), but the configuration seems like a "mild" improvement. If you are looking to order any of the Burson op amps get them directly from Burson. Delivery does take a few weeks, but they are responsive when contacted.
i9-10900k/Asus ROG STRIX Z590-A/EVGA RT X 3080ti FTW3 Ultra/16X2GB Ballistix 3600/2tb Crucial P2/Seasonic X-1250/Topping A50s-D50s-P50 DAC Stack
jonny80s
2019/11/11 21:01:48
I grew some balls and decided to just jam them in, CAPS be damned. Who's afraid of a little soldering if something goes wrong? Still interested if the V6's fit better on the Nu when you get them. Plus the STX is getting dated... and the Nu has better gain control especially for higher impedance headphones.
