Re: Building first EVGA Loop. Confusion - a range of questions
2019/04/11 07:50:26
Most manufactures have already taken your concerns into account. EK blocks are great. Don't worry if you go with those. Use a corrosion resistance fluid that has a reputable name.
You will be able to push your video cards under water to their upper limits. In my experience, the cards failed at higher overclocks, not because of heat limits, rather memory and GPU limits. There will be a ceiling on those components. So yeah, you overclock them as hard as the technical limits of the hardware.
Memory. Samsung and micron meet NVIDIA specs. If you overlcock, seems history has show samsung is a bit better at it. IF you RMA, I doubt you will get any guarantee on samsung memory. RMA is only for defective cards at stock settings. So you won't have any luck there.
"Be quick to listen, slow to speak and slow to anger"
Affiliate Code XZUMV9TJW5
Associate Code: 7PM43CU71IB2IAP
education may be expensive but wait until you get the bill for ignorance
A wise man once said that we can't make anyone feel or do anything. We can throw things into the wind, but it's up to each person to decide how they want to react, where they want to stand when things fall.
