Hello all. I am currently considering a SFF build in the Lian Li Tu-150 using the ASUS ROG Crosshair VIII Impact motherboard. I am struggling with video card selection so I figured I would get some advice here. I would prefer either a 2080S or 2080ti but would also consider a 2070S depending on price and performance. Having never had to worry about the size of my GPU in the past, I am curious what others would recommend in the way of a 2 slot sized card. This will be my first foray into the air cooled world in many years and am looking at a 3900X with a Dark Rock Pro 4 cooler. I would like to be able to put a couple Noctua AF-12s in the bottom to help pull in some fresh air so this is limiting my card selection. What do the wise gurus of the EVGA forums recommend? Thank you all for your advice!
PS, for those that remember me, my 2080ti KPE has been performing wonderfully after the original artifacting and the subsequent RMA. She really is a beast and never goes above 60C in my loop no matter what I throw at it. EVGA’s fantastic service is exactly why I am here looking to purchase yet another EVGA product.
