I recently installed an EVGA Hybrid AIO kit on my 3080 XC3 Ultra. I updated the bios / firmware to the "3080 XC3 HYBRID Kit BIOS" that EVGA_JacobF posted in the "3080 FTW Hybrid Kit Install" topic.
The fans are showing at 2 different speeds at the same percentage (800RPM and 1200RPM, both at 40%). Fan 1 is also only letting me set it to 25% for the lowest speed. Is this normal or should both fans fan the same max RPMs? FYI, Fan 1 shows 2000RPM at 100% and Fan 2 shows 3000RPM at 100%.
After I installed the above bios, Precision X1 said I needed a firmware update, so I did that. I'm pretty sure I was using ver. 1.1.4 at the time. I updated to 1.1.5 and it again said I needed to update the firmware. After updating it's showing the same thing.
post edited by mariomixedup - 2021/01/20 22:27:58
