Another Z390 strange problem, now certain download types do not work.
MhzManiac
  • Ribbons : 8
2021/01/05 21:08:10 (permalink)
So if I try downloading any nVidia, EVGA or other update type file Windows blocks the file. I tell it to execute anyways and I get invalid file error of some type. In the z390 bios file I just downloaded, in file manager it says its 13,788 KB in the zip, but windows says there are no files within it to extract. If I use my windows surface tablet to download these files, then transfer them to my PC, they will run and install normal. If I use the z390 system to download an app or program, they work directly; even one I just did that was 1.4 GB.
  Was thinking mem was running too fast, put things back to factory speeds and it did not change. Using Chrome or Edge browser does not matter. Even killed System Mechanic with no help. Still trying to figure out is it hardware or software? Just seems so strange it's an update type only.
That is me in the picture, anyone else ever pet a live Lion?
EVGA Z390 FTW (Bios 1.08)  i9-9900KF 8 core, 32G Corsair Vengeance LPX Dual Chl 3000 XMP-1 ,
Intel SSD6 M.2 2TB, Samsung 840 PRO 1TB / 512G SSD,   Gigabyte RTX 2080 Super , Win 11 Pro 64, EVGA Supernova 1300 watts, NZXT Phantom 820, Strix Raid DLX 7.1 surround, Corsair H100 Liquid , Dell S2417DG /S2409W / Acer XB241H Predator / Samsung C24F390 Curve/ Oculus Rift S VR
2 Replies Related Threads
    • Ribbons : 122
    Re: Another Z390 strange problem, now certain download types do not work. 2021/01/06 00:54:08 (permalink)
    - Scan your PC for malware ?
    - Windows setting ... only from Windows store ?
    Check:
    "Allow an App through Controlled folder access"  ---> if you noticed a Security pop-up during the Software's install
    Also check the: "Recently blocked apps"
    Handy step by step how to:   Add or Remove Allowed Apps for Controlled Folder Access
    MhzManiac
    • Ribbons : 8
    Re: Another Z390 strange problem, now certain download types do not work. 2021/01/10 10:53:19 (permalink)
    Malwarebytes found nothing and Deep scan with System Mechanic found some minor adware on a backup drive, but nothing that would cause this problem. Thinking now the last windows update may have installed improperly. Using a different ethernet port did not change things so must me windows related.
     Update: well none of that changed anything. I once again downloaded the latest nvidia driver on my tablet and copied to the PC. It runs as normal. So I compared the 2 downloaded files and they are identical in every way. Will try the original file on my tablet just to see if it will expand. I got the same error Non 7Z on my tablet so it has to be corrupting in the way it downloads somehow. Used Edge with no change. I guess its back to playing with the memory settings.
    Well setting ram to AUTO still not helping, always getting this:
    post edited by MhzManiac - 2021/01/10 12:09:08
