https://www.techpowerup.com/301430/alphacool-unveils-core-120-pwm-and-core-140-pwm-series-case-fans Alphacool's fan lineup gets a new addition! The quiet and efficient Core PWM fan is now available in 120 mm and 140 mm, each in 3 different speed variants. The 120 mm version is available with a maximum speed of 2500rpm, 3000rpm as well as 4000rpm. The 140 mm version is available with maximum speeds of 2000 rpm, 2500 rpm and 3200 rpm.
The fan, which can be controlled via PWM signal, is not only suitable as a fan on CPU coolers or radiators. Thanks to its excellent performance values (throughput & static pressure), it can also be used as a case fan. The double-bearing fan axis (>2500rpm) is smooth running and allows for a long service life as well as quiet operation. If you are looking for an affordable and powerful fan without aRGB illumination, you will find it with Alphacool's Core PWM fan.
Features overview
- available as 120 mm or 140 mm version
- high airflow & static pressure
- wide speed control range using PWM
- durable smooth running bearing for quiet operation
- MSRP 6.48€ - 8.98€
For more information, visit the
product page.
Looks like a plain fan with no RGB.
