Nec_V20
- Ribbons : 6
For the first time ever I saw a comparison between a good air cooler and an AIO running on a dual chip Ryzen CPU and as I suspected see https://forums.evga.com/D...-m3001694.aspx#3006758 , the air cooler outperforms the AIO. This is because the air cooler has 100% of its cooling capacity implemented, that is covering the hotspots of the two chiplets; whereas an AIO only has at best 50% of its cooling capacity (where the heat exchanging fins are in the cooler head) covering those hotspots. Source: Hardware Cannucks The Noctua NH-U12S is not even the best 120mm cooler that Noctua has to offer, that would be the Noctua NH-U12A. So I would take the recommendation of AMD to use at least a 280mm AIO to cool the 3950X with a HUGE grain of salt.
PSU: Seasonic Prime Titanium 650 Watt, Case: Phanteks EVOLV X, Mobo: GigaByte X570 AURUS Master, CPU: Ryzen 9 5950X, GPU: Powecolor Red Devil 6900XT, RAM: 32GB (2 x 16GB) Team Group CL16, Cooler: Arctic Liquid Freezer II 360, Boot-drive: Team Group 1TB M.2, Fans: 7 x Phanteks T30 120mm, HD: 5*WD 14TB, 2*WD Blue 2TB M.2 SSD (Games), Keyboard: DasKeyboard 4 MX-Blue, Mouse: Logitech G903, Monitor: ASUS PB287Q (2160p 60 Hz); LG 32GK850F-B (1440p 144 Hz)
flyinion
- Ribbons : 8
Re: AIO vs Air Cooler for Ryzen 3900X/3950X
2019/11/14 10:34:08
Someone really needs to come out with some custom waterblocks that put the jet plate over the chiplet area. Most of the custom cooling blocks the fins do cover them but I've been reading there are optimizations that need to be done to the block designs to better cool Zen2 chips. With that 280mm recommendation looks like I should definitely be looking into a second rad if I upgrade my 3700X to a 3950X next year or a high core count 4xxx series (the plan if it's still AM4 compatible). I think my 30mm 360 is already really pushing it when my 3700X and 2080 Super FTW are really loaded up.
AMD Ryzen 5950X | Asus Crosshair VIII Hero | Gigabyte Gaming OC 4090 w/EK Vector2 | GSkill Trident Z Neo 2x16GB DDR4-3600 | WD SN850 2TB | Samsung 970 EVO Plus 500GB & 860 Evo 2TB | Phanteks Enthoo 719 | Seasonic Prime Ultra Gold 1000W | Steelseries M750 TKL | SteelSeries Prime Wireless | SteelSeries Arctis Pro + GameDAC | Kanto YU2 + Yamaha sub | Schiit Magni 2 Uber & Modi 2 Uber | LG 34GN850 | Asus PG279Q | Win 11 Pro | Custom water loop
Nec_V20
- Ribbons : 6
2019/11/14 10:54:48
Or keep the rad in for decoration and get the Noctua NH-U12A cooler. And before you say it: Noctua has opened a hotline in the US for people triggered by the colour of their fans. The number is 1-800-248 363 Yes, that's 1-800-BITE-ME
transdogmifier
- Ribbons : 17
2019/11/14 10:56:33
Nec_V20 Or keep the rad in for decoration and get the Noctua NH-U12A cooler.
Sounds like the phone number I have for people who are shocked when I say "I Hate RGB"... I can't post my phone number tho.
flyinion
- Ribbons : 8
2019/11/14 11:02:13
LOL I ran a 9 year old NH-D14 over two builds until this one. If I really had an issue with their fans though I could just put Chromax series on them. Also, the rad couldn't just be for decoration. My 2080 is watercooled and was a Hydro Copper SKU so I don't have a factory air cooler for it :)
RainStryke
The Advocate
- Ribbons : 60
2019/11/14 11:23:48
Problem is, that's a 15 minute stress test. A few hours of gaming would show a much different story. The 2 fan AIO water cooling kits are always going to be a better route for those long gaming sessions. I have a Noctua NH-U14S and it does not stand up to my EVGA CLC 280, i'm actually stuck with this air cooler because the case I have that in doesn't fit 140mm fan's and I have 3 AIO's that all run 140mm fans lol
Main PC | Secondary PC Intel i9 10900K | Intel i7 9700KMSI MEG Z490 ACE | Gigabyte Aorus Z390 MasterASUS TUF RTX 3090 | NVIDIA RTX 2070 Super32GB G.Skill Trident Z Royal 4000MHz CL18 | 32GB G.Skill Trident Z RGB 4266MHz CL17SuperFlower Platinum SE 1200w | Seasonic X-1250Samsung EVO 970 1TB and Crucial P5 1TB | Intel 760p 1TB and Crucial MX100 512GBCougar Vortex CF-V12HPB x9 | Cougar Vortex CF-V12SPB-RGB x5 3DMark Results:Time Spy|Port Royal
Asetek Im Hit!
ASETEK Representative
2019/11/14 15:40:17
Yea, saw this too. Too many variables to make such a specific claim. (So says the Asetek guy ;). Fans make a big difference in AIO performance as does the rest of environment. There is also no info on push-pull configs with 3950X just yet. And no 360mm comparison (single fan set or push-pull)...that I have seen so far. Honestly can't wait to get my hands on one for testing. More to come. Nec_V20 For the first time ever I saw a comparison between a good air cooler and an AIO running on a dual chip Ryzen CPU and as I suspected see https://forums.evga.com/D...-m3001694.aspx#3006758 , the air cooler outperforms the AIO. This is because the air cooler has 100% of its cooling capacity implemented, that is covering the hotspots of the two chiplets; whereas an AIO only has at best 50% of its cooling capacity (where the heat exchanging fins are in the cooler head) covering those hotspots.
post edited by Asetek Im Hit! - 2019/11/14 16:34:58
10900K | ROG Z490-Deluxe | 16Gb GSkillz. 3600MHz | EVGA GTX 3080 FTW3 | 34in AOC Ultrawide 144Hz Monitor @3440x1440 Check us out at www.asetek.comRead what we're doing at www.coolnation.com
DEJ915
- Ribbons : 11
2019/11/14 16:27:16
Usually results favour CLC and custom loop since their cold plates are flat vs convex like on normal air coolers which is a poor design for maximum contact on a non-centered die like on Ryzen.
Hoggle
2019/11/14 21:38:43
I take it with a grain of salt since air coolers are very dependent on the case and what is happening with airflow inside for how well they cool. AIO coolers are more forgiving to the case you use and how much airflow is going around the inside. I personally couldn't go back to air cooling since I like the slim profile of AIO but others might want a monster cooler blocking the ability to see inside the case.
Nec_V20
- Ribbons : 6
2019/11/15 01:30:48
RainStryke Problem is, that's a 15 minute stress test. A few hours of gaming would show a much different story. The 2 fan AIO water cooling kits are always going to be a better route for those long gaming sessions. I have a Noctua NH-U14S and it does not stand up to my EVGA CLC 280, i'm actually stuck with this air cooler because the case I have that in doesn't fit 140mm fan's and I have 3 AIO's that all run 140mm fans lol
I would 100% agree with you if you are speaking about a CPU which has the processor chip in the middle of the PCB so that it is completely covered by the heat exchanging fins inside the cooler head Consider however the positioning of the chiplet(s) in the Ryzen 3000 series CPUs: AIOs are just not designed to optimally cool this kind of chip topology, a lot of the cooling potential of an AIO is wasted covering areas of the CPU which do not generate heat compared to the hotspot of the CPU chiplet. It is easy enough to get a picture of the inside of an AIO cooling solution and overlay that over the picture above and you will see just how little of the actual cooling potential of an AIO cooling head is being used. The cooling in the cooling head of an AIO occurs where the heat exchanging fins are, in the picture of the Ryzen 3600 above that would be less than 25% coverage, that is, over 75% of the cooling potential of an AIO is effectively wasted. A good air cooler (such as the NH-U12A) however, would have 50% of its heatpipes covering the area of the hotspot of the Ryzen 3600 pictured above.
- Ribbons : 84
2019/11/15 02:31:00
Personally I still would prefer an AIO over air cooling for a 16 core CPU. I hope that in the future AIO cooling will improve.
2019/11/15 03:56:46
Your point about it being less than ideal make sense; but, would the heat not be conduct fairly well through the heat spreader to a copper heatsink of a quality made AIO. Once the system is heat soaked, temps should stabilize, unless the OC / Voltage was extreme - past the BTU capacity of the cooler
Nec_V20
- Ribbons : 6
2019/11/15 04:10:31
rjohnson11 Personally I still would prefer an AIO over air cooling for a 16 core CPU. I hope that in the future AIO cooling will improve.
I agree with you, here is my current main system: As you can see, I like me my AIO, when I get the 3950X I will do the experiment with an AIO to see if it can cool at least as well as the Noctua NH-U12A I have on the 3600X testbed system I have. I am not however holding my breath. I just don't believe that I will get as good cooling from the AIO, let alone better. Ryzen is outselling Intel by a LOT, the biggest retailer in Germany publishes its sales results and last month, just the Ryzen 3600 (not including the 3600X) sold more units than all of Intel sales of CPUs put together. AIO manufacturers will have no other choice but to react. That is if pressure is put on them by us consumers, who will buy a better cooling solution in the form of an air cooler, rather than get something which looks good, but is inferior in the task it is meant to accomplish. If we do not use the power of our wallet, then AIO manufacturers will not feel constrained to design something which is more appropriate.
post edited by Nec_V20 - 2019/11/15 04:44:12
2019/11/15 05:49:31
Nice Rig
Nec_V20
- Ribbons : 6
2019/11/15 06:07:58
Below you can see the sales for CPUs from the biggest retailer in Germany for September: If this continues, I don't see how AIO manufacturers can avoid adapting their coolers for the Ryzen 3000 series of chips
aka_STEVE_b
EGC Admin
- Ribbons : 69
2019/11/15 07:08:30
I'll never go back to air cooler, mounted hanging sideways w/ 5 lbs pressure pushing on the mounts ... AIO 4 life ....
flyinion
- Ribbons : 8
2019/11/15 09:49:12
aka_STEVE_b I'll never go back to air cooler, mounted hanging sideways w/ 5 lbs pressure pushing on the mounts ... AIO 4 life ....
Yeah I ran the original Noctua D14 for like 9 years over 2 builds. Decided I was done with those kinds of things and did my first custom loop. Skipped AIO's altogether (though I nearly did one of the Alphacool ones).
DEJ915
- Ribbons : 11
2019/11/16 10:10:33
I feel you there, I just built a Ryzen 3600 system for a friend with a tower cooler and after shipping it did not power on. I was like well this is some crap and had another CPU sent over and sure enough somehow the CPU died, it has been a long time but I wonder if the cooler did kill the CPU lol.
flyinion
- Ribbons : 8
2019/11/16 14:55:03
DEJ915 I feel you there, I just built a Ryzen 3600 system for a friend with a tower cooler and after shipping it did not power on. I was like well this is some crap and had another CPU sent over and sure enough somehow the CPU died, it has been a long time but I wonder if the cooler did kill the CPU lol.
Usually they damage the socket in some way. In the "old days" before through motherboard mounting methods when copper heatsinks first were coming out in the early 2000's and the heatsinks used to just attach to the socket itself people actually had issues with the heavier ones ripping the sockets off the mobo.
