Re: 980ti suddenly running 90c and 100% fan speed
2018/08/28 21:47:12
3 years seems to be THE life of these cards, unless they were waterblocked and cooled.
Is your warranty out already? Or did you get the extended warranty?
Any changes to the system, driver update, new game, anything?
Your specs didnt attach, so can you print out what your hardware is?
It sounds like video card went out, or more specifically, the fan controller?
Others will walk you through the thousands of stuff to check, like try it in another system, downclock it, install msi afterburner and see if you can manually adjust fan, and the DDU/uninstall/reinstall/uninstall/safe mode/etc etc etc.
Sajin will help with that stuff.
I7 9700k water cooled-32GB Ram-Zotac 2080 x2 SLI-Asrock Z390 SLI mobo-EVGA 1600W G2 psu-ABS Glass case-2560x1440 144hz IPS monitor-Windows 10 Home
