980ti ACX 2.0 rattle at fan speed > 60%
Beastlycugini
2018/06/27 20:21:38 (permalink)
Just received a 980ti from b-stock, everything works great (huge upgrade from 670). However at fan speeds 55-70ish, there's a noticeable rattle-like sound. Not sure if maybe one of the fans bearings are shot, or if a fin is bent.
Is there anything that can be done about this? it's pretty distracting...
https://youtu.be/YbRUoGYA2Xs (very prominent around 20 seconds)
post edited by Beastlycugini - 2018/06/27 20:32:15
CPU: Ryzen 5 3600
GPU: EVGA GTX 670 FTW
SSD: Samsung 860 EVO 1TB
RAM: Corsair Vengeance 16GB 3000mhz
Case: NZXT s340
Mobo: Asus B350F
PSU: Seasonic GM850
3 Replies Related Threads
    Re: 980ti ACX 2.0 rattle at fan speed > 60% 2018/06/27 20:34:02 (permalink)
    Yep, sounds like the acx fin rattle issue... https://forums.evga.com/L...-to-this-m2210003.aspx
    Beastlycugini
    Re: 980ti ACX 2.0 rattle at fan speed > 60% 2018/07/02 18:10:52 (permalink)
    Would this be considered/worth it for an RMA? Is it a common issue with this cooler?
    CPU: Ryzen 5 3600
    Case: NZXT s340
    Mobo: Asus B350F
    PSU: Seasonic GM850
    Re: 980ti ACX 2.0 rattle at fan speed > 60% 2018/07/02 18:24:52 (permalink)
    You could definitely rma it, or you could do like this guy and fix it yourself.
