Hello,
I need a 12volt, 10 pin adapter cable for my propriestery motherboard CPU slot.
The only ones I can find are 8pin to 10 pins
Is it alright to use 1 pin and turn the 12v's from that into 2pins?
The layout would be
PSU | 8pin -> 10pin | MB
Or is it best practice to say,
Use an 8pin + 6pin to 10 pin, wrapping the extra unused live wires?
My PSU: EVGA 750 G2 / 220-G2-0750-XR
Thank you!
