Re: 770 2gb weird buzzing sound (not coil whine)
2018/02/19 21:06:16
Now that your video links are there, I change my mind. It sounds like one of the fans is rubbing on the heatsink. If a fan is rubbing, usually it is the result of a worn out bearing. With the computer off and the fans motionless, try to wiggle the fans and see if you can detect any defects.
