550W GA power supply paired with a 3060 and a Ryzen 3600
WaterHomie
2021/04/07 14:59:56 (permalink)
Hello,
was just wondering if I would experience any problems pairing a 3060 with a Ryzen 3600 on a 550W GA power supply. I know people were having problems with these PSUs when running either a 3080 or 3090.
9 Replies Related Threads
    bob16314
    • Ribbons : 761
    Re: 550W GA power supply paired with a 3060 and a Ryzen 3600 2021/04/08 02:17:38 (permalink)
    EVGA Product Specs require/recommend a "600 Watt or greater power supply" for all cards in their RTX 3060 Ti lineup..Use the EVGA Power Meter or the more detailed OuterVision Power Supply Calculator (best) to estimate your particular PC's wattage need and see some recommended PSUs.
    aka_STEVE_b
    EGC Admin
    • Ribbons : 69
    Re: 550W GA power supply paired with a 3060 and a Ryzen 3600 2021/04/08 06:51:00 (permalink)
    I wouldn't trust it for very long..... but that's just me.
    Typically it is a good idea to keep a 25% overhead  of what you expect to need in total wattage.
    AMD RYZEN 9 5900X  12-core cpu~ ASUS ROG Crosshair VIII Dark Hero ~ EVGA RTX 3080 Ti FTW3~ G.SKILL Trident Z NEO 32GB DDR4-3600 ~ Phanteks Eclipse P400s red case ~ EVGA SuperNOVA 1000 G+ PSU ~ Intel 660p M.2 drive~ Crucial MX300 275 GB SSD ~WD 2TB SSD ~CORSAIR H115i RGB Pro XT 280mm cooler ~ CORSAIR Dark Core RGB Pro mouse ~ CORSAIR K68 Mech keyboard ~ HGST 4TB Hd.~ AOC AGON 32" monitor 1440p @ 144Hz ~ Win 10 x64
    • Ribbons : 84
    Re: 550W GA power supply paired with a 3060 and a Ryzen 3600 2021/04/08 06:58:32 (permalink)
    aka_STEVE_b
    +1. As recommended above you need a beefier PSU.
    thorandir
    Re: 550W GA power supply paired with a 3060 and a Ryzen 3600 2021/04/29 03:54:53 (permalink)
    To be honest I run the 3600 and 3060 on a 550W Seasonic SII no problem.
    LordSyrion
    Re: 550W GA power supply paired with a 3060 and a Ryzen 3600 2021/04/30 07:05:40 (permalink)
    You CAN do it, but you have a greater chance of running into issues down the road as the PSU efficiency will slowly degrade over time and extended use. Better off using 600-650W.
    Ryzen 9 5900X @ 4.8
    32GB Corsair Vengeance 3600MHZ CL14 (14-16-16-32)
    EVGA 3080 FTW3
    ASUS Prime X570
    1TB Samsung 980 Pro m.2 (OS)
    4x 2TB Samsung 879 EVO
    2x 4TB WD Black
    ASUS ROG Strix 850W White PSU
    walidnsu
    Re: 550W GA power supply paired with a 3060 and a Ryzen 3600 2021/05/04 21:10:44 (permalink)
    WaterHomie
    Hello,
    If you are not planning to do overclock, then it's alright. It has single rail 12 volt providing over 45 amp so I see no problem even with slight overclock.
    abdull74
    Re: 550W GA power supply paired with a 3060 and a Ryzen 3600 2021/05/14 00:48:48 (permalink)
    Gotta side with LordSyrion on this.
    Keep it Simple
    roberty35
    Re: 550W GA power supply paired with a 3060 and a Ryzen 3600 2021/05/14 00:52:36 (permalink)
    Regards,
    Associate Code for a nice discount: 54LU2WY82SCVYVA
    (Don't forget to upload your invoice or no credit is given!)
    jb355
    Re: 550W GA power supply paired with a 3060 and a Ryzen 3600 2021/05/17 22:31:19 (permalink)
    im pulling 530 watts with a 1080ti and 9900ks so 550w is probably not enough, i would look at 650w at least
