cbaty
Hi Gang, I installed the hybrid unit, but I'm lost on how to control the fan LEDs. Can anyone guide me? Thanks!!
post edited by cbaty - 2020/12/22 11:52:27
Save at EVGA checkout using my associates code: XZ8XC0J47NMBVK6 ๐
arestavo
- Ribbons : 76
Re: 3090 Hybrid Fan LEDs... how to control them?
2020/12/22 12:33:48
The latest Precision X1 should have the option under the lighting section.
cbaty
2020/12/22 12:46:48
arestavo The latest Precision X1 should have the option under the lighting section.
I checked and don't see it, unfortunately. None of the options pictured here control them: https://imgur.com/4CDmRlY
arestavo
- Ribbons : 76
2020/12/22 13:11:10
cbaty
The last one on the right is the likely bet, seeing as how the hybrid doesn't have a light bar like the air cooled version. I replaced my hybrid kit's fans with ML120's or I'd check.
cbaty
2020/12/22 13:17:33
arestavo The last one on the right is the likely bet, seeing as how the hybrid doesn't have a light bar like the air cooled version. I replaced my hybrid kit's fans with ML120's or I'd check.
Nope, that would (presumably) control the LED strips if I plugged them into my mobo. At least I can tell you I changed the setting on the right, and it didn't do anything. :)
cbaty
2021/01/27 22:20:23
Anyone have another idea on how to control the LEDs? Thanks!
cbaty
2021/01/27 22:31:07
Installed Asus armory and controlled them. :)
EvgaUser2711201
2021/01/27 23:00:51
Pretty sure if you want to use px1 you have to plug the fans led cable into the gpu led header. The furthest right in px1 led menu is the gpu led fan header option
cbaty
2021/01/27 23:05:35
EvgaUser2711201 Pretty sure if you want to use px1 you have to plug the fans led cable into the gpu led header. The furthest right in px1 led menu is the gpu led fan header option
Thanks. Is that what is labeled 'aux fan' on the end of the card?
EvgaUser2711201
2021/01/27 23:32:40
cbaty
On the end of the card (right above where the lips are) theres 2 different headers. A 3 pin led connection and a 4 pin aux fan header. Its labeled on the hybrid housing. (just noticed that lol)
cbaty
2021/01/27 23:34:28
EvgaUser2711201
cbaty
On my 3090 Hybrid I have 'fan aux' and 'SV/D/G'... annnnnnnnd I just now see imprinted in the mold near the lips it lists the SV/D/G as the LED... thank you!!!
EvgaUser2711201
2021/01/27 23:39:27
Glad I could help! The led ring is pretty nice!
cbaty
2021/01/27 23:40:53
EvgaUser2711201
On my 3090 Hybrid I have 'fan aux' and 'SV/D/G'... annnnnnnnd I just now see imprinted in the mold near the lips it lists the SV/D/G as the LED... thank you!!! Glad I could help! The led ring is pretty nice! I won't lie.. I turned it off.. hahaha I just wanted the 3 EVGA logos to glow (the two on the card, and I also have their 360mm CLC.. all syncing to temp.. so we're chill blue most of the time) Cheers!!
ice water
2021/01/27 23:53:06
cbaty
2021/01/27 23:53:58
ice water use the Precision X1
Thanks. I had them plugged into the mobo, so X1 didn't see them.
