STR3T
Been playing BG3 EA and noticed other 3090's with better FPS at 2k resolution. Heck some even at 4k were showing higher FPS which really then made me go hmmm. So I ran Heaven benchmark at 1600x900 8xAA Extreme and got 203FPS w/ a Score of 5111. Even O/C'ing the GPU like +150 Core and +1200 Mem got lower at 199FPS and Score 5013. Noticed thru GPU-Z that Temps (max temps) were very low, Mem just 62C and then saw max watts for board at just 224. Shutdown, flipped the o/c switch on the GPU, re-ran and got 207FPS and 5216 Score but still watts were just 222 max that run. O/C BIOS is 94.02.42.CO.02 From memory, I think non-O/C BIOS switch showed 94.02-42.CO.05 O/C BIOS under GPU-Z Advanced shows Max Power at 107.1% but Max Power Consumption showed just 52.8% during the benchmark it looks like. This on an EVGA 1000w GQ PSU alongside and 11700k, which is on an LFII AIO and runs nice and cool as well. Oh also on an open CoreTTP3 frame, vertically mounted. I've swapped riser cable on it from stock which seemed to love getting stuck at PCIe 2.0, this one is showing PCIe 4.0 while running Heaven. So don't think it's a PCIe speed issue and don't know where to go from here to get this GPU to use it's full potential. I opened Prec. X1 and it doesn't offer a newer BIOS update...also, yeah now showing non-OC BIOS# (CO.05) even though I've hit the O/C switch and GPU-Z shows CO.02.
arestavo
- Ribbons : 76
Re: 3090 FTW3 not using full power:
2022/09/24 09:49:41
Try uniengine's superposition benchmark instead, or a demanding raytracing game like cyberpunk 2077. Use at 4K resolution and crank the settings up and see what you get - you'll likely see 400+ watts on the stock 450W VBIOS's as read in GPU-Z. Also, cranking the VRAM OC up can drop the FPS when you're on the edge of stability for the 3090s. If you're on a rev 0.1 3090 FTW3, here is a link to the XOC 500W VBIOS (the rev 1.0 cards already had it on the OC switch) - https://forums.evga.com/EVGA-GeForce-30-Series-HYBRIDXOCDefault-BIOS-Thread-m3407542.aspx
post edited by arestavo - 2022/09/24 09:54:37
STR3T
2022/09/24 09:56:28
Thanks for the quick reply arestavo. Under GPU-Z, is Revision A1 = Rev 1.0 you note above? If not, where do I determine Rev version of this GPU?
arestavo
- Ribbons : 76
2022/09/24 10:00:32
STR3T Thanks for the quick reply arestavo. Under GPU-Z, is Revision A1 = Rev 1.0 you note above? If not, where do I determine Rev version of this GPU?
Should show to the right of the PCIE contacts of the card, on the fan side.
the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
2022/09/24 10:02:20
Stop overclocking your memory to +1200. If you are overclocking too much, memory goes into error correcting mode and drastically lowers your scores. Just because you can type in +1200, doesn’t mean you should. You actually shouldn’t. Try stock, and then +500, and then up +100 until your score start dropping, and the remove the last 100 mhz and try again. Heaven at 1600x900 isn’t a great stressor to truly test the card. It’s ok for quick testing, but isn’t putting any real stress. Can you try the 3D mark free versions, and see how they do for performance and scores? What are your GPU-Z perfcap reasons showing as at stock speeds?
post edited by the_Scarlet_one - 2022/09/24 10:05:22
STR3T
2022/09/24 10:13:17
Scarlet, note first run was no o/c's on GPU Core or Mem. Then 2nd run wanted to see if pushing it would increase watts...it didn't. Just a test. I didn't notice PerfCap issues prior, seems like it was all grey/normal. So I re-ran, stock GPU and suddenly it seems to have run as it should: FPS 247, Score 618, Temps from 76 GPU to 89/86 Hot/Mem and saw max 433watts!!?? I changed nothing after switching o/c BIOS on the GPU 1/2 hour ago...was just surfing for same issues, etc. Then re-ran Heaven...BAM. So intermittent issue? I should try BG3 now and see what FPS I'm getting if this holds. If it's the Riser card dropping from 4x to 2x speeds...that would hit FPS a bit but not watts used...right? And PerfCap shown on the "good" run: Pwr, V.Rel and a very small blip near the start that was PwrThermVRel. But 99% was Pwr and V.Rel Cranked up BG3 and still seeing like ~70-90FPS, max watts in game is ~255w. Weird.
post edited by STR3T - 2022/09/24 10:28:53
STR3T
2022/09/24 10:25:46
Superposition 4K: 16,645 w/ avg FPS 124.5, max 153.7, min 104.4. GPU Temp 55 min, 80 Max, Utilization 98%. Max watts per GPU-Z: 425.5watts, hot spot 90c PerCap: Pwr only on Superposition I've seen vids of BG3 at 4k w/ FPS pushing 150+. So something still seems "off" when I get into BG3, not to mention the earlier benchmark runs maxing 225watts. This is...random but at least I can leave BIOS updates out of the solution, it seems. Just have to figure out how to get it running at max power when/as needed for BG3.
post edited by STR3T - 2022/09/24 10:28:24
arestavo
- Ribbons : 76
2022/09/24 10:33:30
Since you're running a PCIE extender, you may want to give it a test without to rule that out. My memory isn't what it used to be, yet I seem to recall similar issues popping up over the last two years when folks were using extenders.
STR3T
2022/09/24 10:37:00
Grrr but yeah. Whole point of P3 is vertical beauty. But sitting here thinking about this...that's what I'm leaning toward as well. In fact, my son's PC is similar, so I may just swap his 3090 w/ mine and see how it does in his setup and his in mine. I'll test his first, make sure it's working as advertised on some benchmarks. Got the LFII service kit this past week, so I may as well do that while swapping GPU's, etc. and give her a nice clean-up to boot. Thanks for the help...weird that it was random but glad it's been narrowed down and at least see I "can" get full perf out of the 3090.
arestavo
- Ribbons : 76
2022/09/24 11:08:35
Someone else can chime in, but I seem to remember that a high quality PCIE gen 3 extender was a fix for some people, as the PCIE gen 4 would have issues. Again, my memory isn't what it was so I may be incorrect. Checking the 3090s between systems is a good idea, especially if your son's is a known good system without this issue.
post edited by arestavo - 2022/09/24 11:09:43
STR3T
2022/09/24 16:20:39
So tried this first before the big time consuming swap...went into BIOS and locked PCIe to Gen 3. Working like a champ. Probably missing a few FPS but good enough at this point vs. roulette with various riser cables.
