Satsugai7
Hi there. Upon receiving my 3090, I installed Precision X1 and it informed me that there was a firmware update for my card. Upon pressing start, the window disappeared, with the fans ramping to 100% and 4 red lights turning on. I waited for about 20 minutes and the card just stayed stuck in this "flash mode" with the 4 red lights on and the fans at 100%. I then attempted to run the firmware update again, with the same result. I tried powering off and on, with the same result... from there I did the following: I've run DDU to clean my windows drivers. (version: 456.55-desktop-win10-64bit-international-dch-whql) I've reinstalled said drivers. I've reinstalled Precision X1 and attempted it again. I've disabled my antivirus software and attempted to run the firmware update. None of these fix the problem. EDIT: Resolved in thread below. If you are having this issue, please scroll down. Thanks
post edited by Satsugai7 - 2020/09/30 20:15:57
leezon
Re: 3090 FTW3 Ultra stuck in flash mode (4 red lights and 100% fan)
2020/09/30 19:51:22
Use the little bios switch and switch it over to the other bios until you figure it out. Sounds like maybe a power draw issue or something during the flash that has messed up that BIOS.
arestavo
- Ribbons : 76
2020/09/30 20:10:36
leezon Use the little bios switch and switch it over to the other bios until you figure it out. Sounds like maybe a power draw issue or something during the flash that has messed up that BIOS.
I don't think that's a FTW3 card, the XC3 series and Black are single VBIOS.
Satsugai7
2020/09/30 20:11:40
☼ Best Answerby Afterburner 2020/09/30 20:12:16
Resolved issue. I looked at the event viewer and Administrative Events and found the below error. Some searching on "d3d9.dll fault module" resulted in others having similar issues with other software. The culprit was RSS & MSI Afterburner. If anyone else runs into this issue please uninstall RSS (Rivatuner Statistics Server) and MSI Afterburner. I restarted after uninstalling both, and the firmware update completed successfully. You can then reinstall RSS & Afterburner if you so choose. Faulting application name: FirmwareUpdate.exe, version: 1.1.0.0, time stamp: 0xb245efaf Faulting module name: d3d9.dll, version: 10.0.19041.488, time stamp: 0xb2d4d95c Exception code: 0xc0000005 Fault offset: 0x000000000000b280 Faulting process id: 0x73c Faulting application start time: 0x01d6979e73fcb63a Faulting application path: C:\Program Files\EVGA\Precision X1\Library\FirmwareUpdate.exe Faulting module path: C:\WINDOWS\SYSTEM32\d3d9.dll Report Id: fa75baf4-ddaa-4b5a-ac9f-dcaab21974c8 Faulting package full name: Faulting package-relative application ID:
Afterburner
- Location: It's... Classified Yeeeeeeeeeeaaaaaaah........
- Ribbons : 110
2020/09/30 20:13:58
I believe that is the first time I came into a thread and gave a Scooby Snack, to the person that started a thread with a problem and solved it themselves while helping others... Good work!
Hoggle
2020/09/30 20:16:46
Glad it was fixed and sorry that it was an issue. I am also happy to hear it was found to be the other software since while not EVGA software it's still pretty common software that others could run into problems with. It's also important to remember if new firmware comes out to remove these programs just in case.
TheGuz4L
2020/10/01 09:03:52
Does MSI Afterburner even work with the latest EVGA fan profiles? No reason to have it installed I think now.
antibonk
2020/10/01 10:38:20
This is good information to know once my 3080 FTW3 arrives this weekend, as I was using MSI afterburner with my current card. Saved me some potential frustration!
skylerfly16
2021/05/14 16:01:20
After a full format without having MSI afterburner onboard, my FTW ULTRA 3090 still has all 4 red lights on the PCIE slot, and my PX1 is missing the RGB TAB. My fans are at 100% and I can hear them, but PX1 doesn't report my RPMs.
comeonson69
2021/08/27 15:33:43
skylerfly16 After a full format without having MSI afterburner onboard, my FTW ULTRA 3090 still has all 4 red lights on the PCIE slot, and my PX1 is missing the RGB TAB. My fans are at 100% and I can hear them, but PX1 doesn't report my RPMs.
Did you get this resolved? I am having the same issue.
KingEngineRevUp
- Ribbons : 9
2021/08/27 16:18:44
OG979
2022/08/09 14:26:14
I had the same issue with my 3080. I don't have MSI afterburner or RSS. If I do, I don't see it where I can uninstall them in my programs. Anyways, EVGA recommended RMA after 3 phone calls. Thank god I had a protection plan from Microcenter. I now have a 3090 and once I click on Precision x1, I'm leary to even let it run. I closed it out. Thoughts anyone? I know this is really old post.
- Ribbons : 135
2022/08/09 14:31:04
OG979 I had the same issue with my 3080. I don't have MSI afterburner or RSS. If I do, I don't see it where I can uninstall them in my programs. Anyways, EVGA recommended RMA after 3 phone calls. Thank god I had a protection plan from Microcenter. I now have a 3090 and once I click on Precision x1, I'm leary to even let it run. I closed it out. Thoughts anyone? I know this is really old post.
Ensure you have both CSM and whatever form of 'Fastboot' your BIOS has is disabled. Also disable Windows fast boot as well. I've never had a problem with Afterburner interfering with a BIOS flash, driver install or pretty much anything else for that matter. The only thing I've used Precision for was to update the firmware on the GPU when I first got it. Otherwise, I run Afterburner. It is more stable.
OG979
2022/08/09 21:31:12
Should I also disable my Nortons antivirus/firewall? This is a new card.
- Ribbons : 135
2022/08/09 21:45:38
OG979 Should I also disable my Nortons antivirus/firewall? This is a new card.
Probably not a bad idea. Some commercial antivirus programs freak out with BIOS flashers. I've just been using Windows Defender for over a decade and never had an issue.
OG979
2022/08/10 05:32:02
Also, did you disable window defender when updating the firmware?
- Ribbons : 135
2022/08/10 13:35:56
OG979 Also, did you disable window defender when updating the firmware?
I've never had an issue with Defender causing an issue, ever. Not sure why folks use third party AV anymore when Defender is updated almost daily and is designed natively to operate with the system.
