Re: 3080 XC3 Ultra Power Draw Issues
2021/10/28 10:40:58
Which EVGA power supply are you using?
I was using an EVGA 700w BR and was experiencing the same issue with my 3080 ti XC3, I was stuck @ 280w max. I switched to an 850W GQ and the card now pulls 320-350w as it should.
It appears if the power isn't clean enough these cards limit the power usage. Just because it's an EVGA psu doesn't mean its high quality.
Although if you have one of their gold units, that *should* be good enough..no guarantees though.
5800x, 32gb b-die @ 3800 cl15, Gigabyte Aorus Pro Wifi, EVGA 1000 G3, RTX 3080 ti ftw3 ultra, RTX 3080 ti ftw3 ultra hybrid, RTX 3080 ti XC3, custom loop
