Re: 3080 Ti XC3 Fan Bearing Noise
2021/10/14 04:49:57
Welcome to the fan noise club! Not sure what’s up with some of these EVGA 3000 series cards, but several users, myself included, have experienced similar noises at certain fan speeds. What seems to work for my 3080 is setting the fans to 100% or using the card under a load that cranks their RPM up rather high. Once the RPM comes back down, the noise seems to subside. Definitely seems like a cheap bearing issue since no fan blades are hitting anything.
