sstevens5
My 3080 is coming and I’m looking to bump my SeaSonic Focus PX750 to 850. I have confirmation I can re use my braided CableMod cables as the pin outs are the same. However, with a 10700K, 4 case fans, 2 monitors (1 gaming is 1080p but looking to go 1440p soon), 2 SSD’s, etc I’ve been told that some 3080/90 are having transient spikes to almost 600W? Is this true? I’m not overclocking at the moment but I do plan to do a little with the gpu and probably the cpu soon. 1000W seems a little overkill but then again I don’t want to cut corners. Nvidia recs 750 as a minimum so I just want a peace of mind with a little headroom and unfortunately basically all 1000W and most 850W are sold out with SeaSonic (don’t want to re cable). Input is welcomed and reassurance is appreciated!
kevinc313
- Ribbons : 22
Re: 3080 FTW3 - total consumption and spikes? Upgrading psu need advice
2021/04/06 06:04:52
undecided65
2021/04/06 08:06:59
sstevens5 My 3080 is coming and I’m looking to bump my SeaSonic Focus PX750 to 850. I have confirmation I can re use my braided CableMod cables as the pin outs are the same. However, with a 10700K, 4 case fans, 2 monitors (1 gaming is 1080p but looking to go 1440p soon), 2 SSD’s, etc I’ve been told that some 3080/90 are having transient spikes to almost 600W? Is this true? I’m not overclocking at the moment but I do plan to do a little with the gpu and probably the cpu soon. 1000W seems a little overkill but then again I don’t want to cut corners. Nvidia recs 750 as a minimum so I just want a peace of mind with a little headroom and unfortunately basically all 1000W and most 850W are sold out with SeaSonic (don’t want to re cable). Input is welcomed and reassurance is appreciated!
I ran a 3090 with a Corsair RM750x so with a 3080 you should be fine with even less. My Kill-a-watt showed total consumption of under 500W with 3 SSDs, 1 NVME, a Ryzen 3800x and a 3090 FE while gaming.
kevinc313
- Ribbons : 22
2021/04/06 08:12:13
undecided65 I ran a 3090 with a Corsair RM750x so with a 3080 you should be fine with even less.
Whew lad.
undecided65
2021/04/06 08:18:55
kevinc313
Whew lad.
I know! I was just testing it in a different PCs to see if I could make the coil whine go away. Worked fine in a TM850x, RM750x and finally in my RM1000i which also showed under 500W total consumption under gaming through its internal usb-bus reporting.
jankerson
2021/04/06 08:19:51
undecided65
An FE is NOT, I repeat NOT a 3080 FTW3. And Kill Watts aren't accurate, not even really close to being accurate.
i9 9900K @ 5.0 GHz, NH D15, 32 GB GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q, Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W. i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W. i7 8700K, AORUS Z370 Ultra Gaming, 16GB 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
jankerson
2021/04/06 08:20:48
More like over 900W Transient power spikes for the 3080 FTW3 Ultra.
undecided65
2021/04/06 08:22:35
jankerson
undecided65
Also used the RM1000i internal reporting which matched the kill-a-watt so it must be close enough.
aka_STEVE_b
EGC Admin
- Ribbons : 69
2021/04/06 08:23:24
A solid name brand 850W should be just fine...
jankerson
2021/04/06 08:23:54
undecided65
jankerson
undecided65
From the wall means NOTHING.
jankerson
2021/04/06 08:26:55
aka_STEVE_b A solid name brand 850W should be just fine...
Right, at the min.
undecided65
2021/04/06 08:34:35
jankerson
undecided65
jankerson
undecided65
No, I mean the RM1000i comes with a usb cable that connects to a motherboard USB header and it reports all its data. The include the input wattage from the wall as well as output voltages and watts. Also, the 3090 FE maxes out at around 390W according to the nvidia hud.
kevinc313
- Ribbons : 22
2021/04/06 08:37:47
undecided65 I know! I was just testing it in a different PCs to see if I could make the coil whine go away. Worked fine in a TM850x, RM750x and finally in my RM1000i which also showed under 500W total consumption under gaming through its internal usb-bus reporting.
Might be OK with a name brand PSU. My 2080 Ti runs fine at max power (more than a stock 3090 FE) with a 650W G1+ and a low power CPU with few peripherals. But I wouldn't trust a 3080 FTW3 with anything less than a top tier, very high performance 1000w PSU....
post edited by kevinc313 - 2021/04/06 08:41:03
jankerson
2021/04/06 08:38:26
undecided65
jankerson
undecided65
jankerson
undecided65
That IS NOT A 3080 FTW3 ULTRA. They pull every bit of 450W+. I have seen mine pull as much as 525W, measured from my AXI 1600. And that's not including the 900W+ transient power spikes.
undecided65
2021/04/06 08:50:48
jankerson
undecided65
jankerson
undecided65
jankerson
undecided65
ok man, I withdraw my previous post ;)
sstevens5
2021/04/07 08:41:51
So after more reading I feel like I need to have a PSU on standby...
As stated I have the SeaSonic Focus PX750 now. I’m looking at another SeaSonic strictly because of their rep and the fact I already have braided cables in my system that I can use.
However I am looking at Corsairs AX850 Titanium (in stock) or an RMx 850 or 1000. I will admit, I impulsively ordered a SeaSonic PRIME TX850 yesterday but then just today started reading and was routed to some posts that the PRIME was mishandling certain issues worse than the FOCUS line?? Even JonnyGuru himself was discussing. It all seems so hit or miss.. looking for advice! Again, if I go with another PSU manufacturer I’m going to be ordering new cables as well so that’s added $$
undecided65
2021/04/07 08:46:31
If you are gonna spend the $$$$ go for a 1000W. It will last you into the next gen of cards :)
sstevens5
2021/04/07 08:50:05
undecided65 If you are gonna spend the $$$$ go for a 1000W. It will last you into the next gen of cards :)
Just unsure which brand to go with! FOCUS PX1000 would be my choice but OOS everywhere
undecided65
2021/04/07 08:52:27
sstevens5
Check Corsair, the RM1000i was in stock. That's what I bought. [edit] Ooops, sold out...
undecided65
2021/04/07 08:55:24
It's the miners, they are buying anything 1000W+
kevinc313
- Ribbons : 22
2021/04/07 09:33:35
sstevens5 So after more reading I feel like I need to have a PSU on standby...
This is the first I'm hearing of the Prime series having any issues, they are some of the best testing PSU's for transients. Keep in mind Gold PSU's usually have better transient response than the Ti or Plat versions.
sstevens5
2021/04/07 09:37:49
kevinc313
Can you elaborate or link discussions on why the transients are better in golds? Here’s the discussion on the Prime units: https://forums.tomshardwa...3692042/#post-22258294
JayManB
2021/04/07 09:48:17
I'm using a Corsair RMx850. So far everything has been great no shutdowns or anything weird happening. I'm also using a mildly overclocked 10700k. The most I've seen my 3080FTW3 pull was 380 watts according to GPUz and it only really pulls this much in benchmarking programs. When I play games at 1440p 144hz it usually pulls around 320-350. I cap my framerates so I stay in the G sync range during gaming. This card is crushing 1440p. The disclaimer is I don't overclock my 3080 so its running around 1920 clock speed. I'm also using the stock bios and not the 450w bios. If I were buying today I would probably go for 1000w just for piece of mind but I think 850w will get the job done. Enjoy your new card.
post edited by JayManB - 2021/04/07 09:50:19
kevinc313
- Ribbons : 22
2021/04/07 10:00:10
sstevens5
kevinc313
Just my opinion after reading dozens of reviews in detail. Ti units usually give up the most for the sake of efficiency. Plat and gold units are usually similar. "750w Platinum Seasonic Powersupply" is not a prime. Johnny Guru is talking about an 'issue' with 12V sense, which may or may not be related.
post edited by kevinc313 - 2021/04/07 10:05:49
Pwnstix
2021/04/07 11:53:28
Thanks for linking that post. I wish I'd looked into transient response more closely before I'd got any of my Prime units. I didn't think I'd have to worry about it. But I'm getting reboots/shutdowns with my 3080 and TX-1000, and it does the same on my older Prime Titanium 750W. I'm looking into getting another PSU,but. ,yeah they're all out of stock.
CPU: AMD Ryzen 7 5800X Motherboard: Asus ROG X570 Crosshair VIII Dark Hero RAM: 32GB (2 x 16GB) G.Skill Trident Z Neo DDR4-3600 CL16 F4-3600C16D-32GTZN GPU: EVGA GeForce RTX 3080 10 GB FTW3 ULTRA GAMING Storage 1: Samsung 850 Pro 1 TB 2.5" SSD Storage 2: Samsung 870 Evo 4 TB 2.5" SSD Storage 3: Samsung 970 Evo 1 TB M.2 NVME SSD PSU: EVGA SuperNOVA P2 850W Case: Corsair Air 740 ATX Full Tower Case UPS: CyberPower CP1500PFCLCD
kevinc313
- Ribbons : 22
2021/04/07 12:13:18
Pwnstix Thanks for linking that post. I wish I'd looked into transient response more closely before I'd got any of my Prime units. I didn't think I'd have to worry about it. But I'm getting reboots/shutdowns with my 3080 and TX-1000, and it does the same on my older Prime Titanium 750W. I'm looking into getting another PSU,but. ,yeah they're all out of stock.
No BSOD, just hard reset? Would be interested to hear more about the 12v sense issue Jonny Guru mentions.
post edited by kevinc313 - 2021/04/07 12:45:11
sstevens5
2021/04/07 12:48:22
SeaSonic PX850 incoming. This will replace my PX750. I’m putting the cart before the horse since I haven’t received my 3080ftw3 ultra yet. I know wattage may not cover certain issues but if both of my units perform well, I’ll be selling the PX750. Had to snag the 850 due to shortages while I have the chance.
Excuse the ignorance but are there any specific tests or screenshots I should post once I have my GPU for testing? No plans to overclock the 10700K and I will run with factory 3080 settings before I touch or feel I’m okay to go with the 450w bios OC. Will report back
Rygar1976
2021/04/07 12:49:12
jankerson
Where exactly are you seeing/recording these transient spikes? The specs in my build are listed in my signature below - my GPU has never pulled more than 512watts from the official 500 watt XOC Bios. I've since updated to the latest BIOS (3090 FTW3 Ultra version - since there is no hybrid-converted BIOS) and I get better performance, but I've never seen it pull more than about 485 - 500 watts in GPU-z. I HAVE seen it pull as much as 83w through my PCI-E slot though, which I'm not sure if I need to worry about or not (considering my Mobo) as I know people are RMA'ing 3090s that pull more than the normal 75w from the PCIe slot. As far as PSUs - with a hefty OC on both my i9-10900k, my RAM, and my 3090 - I'm using a 1000w EVGA G3 - but EVGA's own website tells me I really only need 750 watts. **I also have a brand new - still shrink-wrapped Corsair HX1000i Titanium PSU I am looking to sell - feel free to PM me if anyone is interested. Ill sell it lower than any advertised price to a fellow GAMER (i.e. non-Miner) since I know the prices and availability are F'd atm. (/edit - actually I have pretty much everything needed for a SWEET gaming rig for sale, other than RAM, GPU and a cooler for the CPU. - I have a 3 month old i7-10700k, 3-month old Asus Rog z490 F-Gaming Mobo, 3-month old Lian Li Dynamic 011 Case, 3-month old 8 x Corsair QL 120mm aRGB fans, 1 x 140mm QL Fan, 2 x ML 120mm Fans, 2 Lighting Node Pros and 2 LED Node Pros, 2 x EVGA 3300 RPM Fans from Hybrid Kit that are 100% unused, CoolerMaster ELV8 aRGB GPU anti-sag support, and the Corsair HX1000i Titanium PSU lol.)
post edited by Rygar1976 - 2021/04/07 12:55:48
i9-10900k 5.3GHz allcore -5.1 Bus@1.39v Daily OC - Kraken x73 with 6 x 120 Noctua NF-F12 iPPC 3000 RPM Fans in Push-Pull Asus z590 Maximus Hero XIII Motherboard 4 x 8GB G.Skill TridentZ 4000MHz@CL15-15-15-30 EVGA 3090 FTW3 Ultra + Hybrid Conversion: - Kryonaut Extreme + Fuji Poly Thermal Pads - 4xNoctua NF-F12 iPPC 3000RPM Fans Push-Pull - 2.205GHz at 1.053v - 9.951GHz VRam Daily OC 2TB 970 Evo Plus Boot M.2 2TB Sabrent Rocket M.2 2TB WD Sata M.2 2TB 960 EVO SSD Lian Li Dynamic XL Case 17 Total Noctua NF-F12 iPPC 120mm 3000RPM Fans
kevinc313
- Ribbons : 22
2021/04/07 13:09:02
sstevens5 Here’s the discussion on the Prime units: https://forums.tomshardwa...3692042/#post-22258294
Just for some context for some people. "jonny guru" currently works as director of R&D for Corsair. They have some PSU's made by Seasonic that use the Prime platform, that have a minor, known issue with what are apparently the +12V "sense" wires (thinner, doubled up wires on the 12V pins, used to monitor voltage), where there is noise on that wire.....?
post edited by kevinc313 - 2021/04/07 13:31:46
Rygar1976
2021/04/07 13:43:03
kevinc313
I hate to sound like this, or even say this - but I've never bought Seasonic and probably wont, unless I'm building a generic rig. I don't know a whole lot about the brand, but I personally consider them a middling product and priced as such. I'd stick to the brands most commonly used by pc and pc gaming enthusiasts personally - i.e. a Corsair or EVGA... MY RM1000i blew after about 5 years, and Corsair couldn't find me a replacement, which is how I ended up with a brand new, still shrink-wrapped HX1000i that I am going to sell. I am CURRENTLY running my PC on EVGA's 1000w G3 and it's working absolutely perfectly. I WAS running my i7-10700k and Asus z490 F-Gaming Mobo on a EVGA 1000w GQ and it ran perfectly too. The only real difference being the GQ has the main motherboard ATX connection hard-wired, where the G3 is 100% fully-modular. Either would work for you, including the 800w.
post edited by Rygar1976 - 2021/04/07 13:49:17
