Sahira
How does this card really behaves in terms of noise (coil whine and fan spinning) ? Your input will be much appreciated.
post edited by Sahira - 2021/10/21 05:01:26
aka_STEVE_b
EGC Admin
- Ribbons : 69
Re: 3070 ti FTW3 Ultra Fan Noise + Coil Whine questions [For the owners]
2021/10/21 05:57:44
My son is using that card & he hasn't complained-nor have I heard it making much noise. As always though, it's kind of luck of the draw
staypuft
- Ribbons : 31
2021/10/21 06:11:46
As noted in the other thread... No coil whine on my 3785 XC3 Ultra (Seasonic Focus GX-850). My friend has the 3797 FTW3 Ultra (Corsair RM850x) and reports no coil whine.
Interested in a discount on EVGA products? Click here for details and enter this Associates code at checkout >> 2ILPLQQ8IWY8DPN 2021 Build: Gigabyte Z590 Ultra | Core i7-10700K | be quiet! Dark Rock Pro 4 | 32GB G.Skill Trident Z DDR4-3200 EVGA RTX 3080 FTW3 Ultra | Samsung 970 EVO 500GB | Seasonic Focus GX-850 | Fractal Design Meshify C | Asus TUF VG27AQL1A
icehotshot
2021/10/21 07:07:40
I have a ftw3 ultra and it make no coil wine. Ensure you have a quality power supply and you should be good to go. Seems like these 30 series cards are very finicky about getting quality power from the power supply.
5800x, 32gb b-die @ 3800 cl15, Gigabyte Aorus Pro Wifi, EVGA 1000 G3, RTX 3080 ti ftw3 ultra, RTX 3080 ti ftw3 ultra hybrid, RTX 3080 ti XC3, custom loop
joseph305
2021/10/21 07:11:46
my 3797 has a loud 3rd fan ... had to configure a special fan curve for it... Once the 3rd fan hits around 50% or higher , it's unbearable ....
10700, msi z590 mb ,16gig ram, 3070ti ftw3 ultra, win 10 , crucial m.2's
Sahira
2021/10/21 09:54:02
joseph305 my 3797 has a loud 3rd fan ... had to configure a special fan curve for it... Once the 3rd fan hits around 50% or higher , it's unbearable ....
Oops, wasnt a firmware specially for that ?
ObscureEmpyre
- Ribbons : 7
2021/10/21 10:06:28
icehotshot I have a ftw3 ultra and it make no coil wine. Ensure you have a quality power supply and you should be good to go. Seems like these 30 series cards are very finicky about getting quality power from the power supply.
I’ve heard that some PSUs cause GPU coil whine, but I have several EVGA GPUs that exhibit it even after having experimented with different PSUs from different reputable brands such as Corsair and EVGA, all ranging from 80+ gold to 80+ titanium. I’ve also used stock PSU cables as well as individually-sleeved aftermarket ones. The cards still whine.
joseph305
2021/10/21 10:29:04
well, I have the latest firmware ... 1.2.6 ... I don't think it's coil whine , but it could be, not going to buy another power supply to test using evga 850 bq ps.. as long as I have that 3rd fan stay below 60% speed, I can handle noise.. but I haven't run any demanding games yet either, just benchmarks and stress tests.. , maybe when I buy a game that pushes gpu , say like CP2077 or metro exodus enhanced, the fans might not hit 60% anyways. I'm sure there will be some game sales soon .. still have about a month left to stepup too..
Ryheart
2021/10/21 17:29:45
Omg I got 3070 ti ftw as well and I can hear the coil whine. I'm using the NZXT h1 case with the included rebranded seasonic 650W PSU. I have lodged to have it replaced with my retailer but currently waiting on stock. I used to have a 3080 ultra which did not whine but I sold it for extra cash.
RideRaptor
2021/10/22 08:03:03
Yes mine has coil whine 3070 TI FTW3 I have a 750 Watt CoolerMaster power supply I'm running on PCI express 3 Should be able hear it on this link. How do you fix it? It's annoying
RideRaptor
2021/10/23 20:33:13
Will the power link work on these cards to clean and make power stable or reduce noise? It doesn't have these cards listed.
