I am hoping that what I'm seeing is by design. Using GPU-Z and monitoring the power draw on each of the 3 8-pin connectors the 3rd connector is consistently drawing less than half the power of the other 2 connectors. IE. plugs 1 and 2 may be drawing 120 watts each but the 3rd plug will be drawing less then 60 watts. Is this normal?
