Sixtus23
Re: 2080ti ftw3 fan problems
2018/10/28 16:53:32
We are already talking about possible max speeds at 3x100%
post edited by Sixtus23 - 2018/10/28 16:56:36
jsteedman
2018/10/29 09:49:03
GTXJackBauer That's ICX2 working folks. If you want all your fans running at the same speed you'll need to set them at a fixed speed.
The main problem is fans 2 and 3 tend to crash, that isn't an ICX2 working thing... That being said in X1 if i set the fan to auto, THEN go to the fan curves and set to use the enable automatic fan control on the fan curve page I have yet to have fans crash. But I have had fans manually set to 100 that after 10 seconds drop to 0, then eventually stop showing up at all until all the power is drained from my PC. So there seems to be some sort of firmware problem crashing code hard on the cards requiring a hard reset.
Andrew_K
2018/10/29 10:51:41
jsteedman
I have similar issues, though they aren't consistent. Setting fan speeds manually never works for me and they eventually just shut off and stay shut off until I flip it back to auto. It's been very odd and buggy. Maybe .334 that was released today will fix it.
EVGA_JacobF
- Ribbons : 26
2018/10/29 10:54:06
jsteedman
2018/10/29 11:08:16
If nothing else without a new fan curve set if the fans are linked they eventually after a couple of seconds reach a control point where they are essentially all the same and 100 percent has all 3 fans right around 3000. So with 3.3.4 that whole thing went away. I'll keep the curve that was doing weird things active for a while to test.
aj_hix36
2018/10/30 01:03:47
After using 0.3.4 all day, it is STILL BROKEN. If I run your PX1 all day, and come back to my computer, fans 2 and 3 stop working and refuse to function until I power flush my system. Seriously, I keep reporting this version after version after version, and still nothing.
Andrew_K
2018/10/30 07:40:39
aj_hix36 After using 0.3.4 all day, it is STILL BROKEN. If I run your PX1 all day, and come back to my computer, fans 2 and 3 stop working and refuse to function until I power flush my system. Seriously, I keep reporting this version after version after version, and still nothing.
Does this happen while gaming? It shouldn't matter if they turn off while idle. I haven't had a chance to test the new px1 yet myself.
aj_hix36
2018/10/30 10:53:58
Andrew_K
They go permanently off so yeah its a pretty big problem.
EVGA_JacobF
- Ribbons : 26
2018/10/30 11:02:10
Can you confirm if you are using the default fan curve and/or are you using a custom fan speed?
aj_hix36
2018/10/30 11:09:22
EVGA_JacobF Can you confirm if you are using the default fan curve and/or are you using a custom fan speed?
Custom fan curve. I turn off hwm as well.
jhod10
2018/10/31 03:21:02
Got mine yesterday and upgraded from a 1080 FTW2, I uninstalled the old OXC, removed the card, put new card in, let NVIDIA do it's thing checked for updates there. The down loaded 3.4 and started running games on max settings. I have had no issues no fan stoppage and LED seem to all work fine. Have no overclocked and won't for some time, I am pushing max frame rate on Black Ops and WoW with max settings on a 27 inch 1440p. I would not that with an i5 8600k and 32gb of 3000 ram I am bottle necking load wise on my chip so recommend and i7 or i9 with this card to get the full potential.
MuXuSS
2018/10/31 04:07:01
jhod10
2018/10/31 04:07:53
jsteedman
2018/10/31 04:38:47
My fan issues would have popped back up by now, there was something flashed when i installed 3.4 and sometimes when the fans start they will spin up really high and then fall back down to where they were. But either the flash for what was an LED fix fixed it, 3.4, or both. I set two fans to 0 and one to 20 and then underload they all go to 60 and its been working since i switched, and I even did some OC testing that would have blown it up for sure before using 3.4.
aj_hix36
2018/11/03 12:16:53
- Ribbons : 282
2018/11/03 12:39:52
