Hot!2080 ti kingpin power draw issues
Jahusaphet
2019/04/12 21:15:39 (permalink)
So I was setting up my sli when one of my card started reporting 1600w power usage. I turned everything off and tested board with other card and all seemed fine. Then the power supply an evga 1200 p2 supernova stopped powering either card. Using a new power supply and the one broken card I am now seeing 850w and 300 mhz on the core clock stuck. Can someone help me. I've tried using the normal and oc bios. There is no way it's actually pulling this much since the temps are so low.
post edited by Jahusaphet - 2019/04/12 21:36:05
55 Replies Related Threads
    degenerate
    Re: 2080 ti kingpin power draw issues 2019/04/12 21:21:22 (permalink)
    Are you using PX1?
    Jahusaphet
    Re: 2080 ti kingpin power draw issues 2019/04/12 21:22:55 (permalink)
    After burner and or px1 reporting same watts on card oled aa well as in px1. Seems to be locked in low power state.
    degenerate
    Re: 2080 ti kingpin power draw issues 2019/04/12 21:32:57 (permalink)
    Jahusaphet
    Have you checked with GPU-Z to verify there as well? I noticed last night that the readings PX1 was giving me weren't accurate (temps in ICX2 screen were accurate strangely enough)... I noticed high power usage and high temps being reported when in fact the card is just idling (verified with GPU-Z). I am sticking with Afterburner/Classified Tool for now except for when I want to make use of the ICX2 sensor feature in PX1.
    Also what is your Power Management setting in NVCP?
    Jahusaphet
    Re: 2080 ti kingpin power draw issues 2019/04/12 21:39:46 (permalink)
    degenerate
    Jahusaphet
    GPUZ is reporting higher power draw at 1500w. It was max perf. And is now on optimal power. Have tried to go back a driver and reinstall drivers. Other kingpin card is doing fine.
    • Ribbons : 276
    Re: 2080 ti kingpin power draw issues 2019/04/12 21:43:32 (permalink)
    I think the OLED needs some TLC from EVGA before we can trust what it is telling or showing us ATM.
    1500 Watts?
    If you are using the "Classified Tool" Stop and see how you Cards Run without it.
    post edited by bcavnaugh - 2019/04/12 21:46:50
    Affiliate Code: E5L3CTGE12 & Associate Code: 9E88QK5L7811G3H
    Jahusaphet
    Re: 2080 ti kingpin power draw issues 2019/04/12 21:48:20 (permalink)
    1500 Watts?
    I agree. And yes to your question, but I am not using the classified tool. The other Kingpin card is running perfectly. Looks like I'm going to have to RMA before I can SLI...
    post edited by Jahusaphet - 2019/04/12 21:52:05
    • Ribbons : 276
    Re: 2080 ti kingpin power draw issues 2019/04/12 21:51:56 (permalink)
    I find it really hard that you are going to have to RMA your Card(s).
    Need to know more about your Hardware to see the whole Story.
    "300 mhz on the core clock stuck." You card is not stuck.
    What Monitor is Connected to this Card, if SLI and Not the Primary Card then this is normal.
    post edited by bcavnaugh - 2019/04/12 21:55:07
    Jahusaphet
    Re: 2080 ti kingpin power draw issues 2019/04/12 21:52:42 (permalink)
    Whys that?
    Jahusaphet
    Re: 2080 ti kingpin power draw issues 2019/04/12 21:53:48 (permalink)
    Posted a picture in the first post. That's what msi is reporting as well as PX1. And GPU-z reports 1500w.
    • Ribbons : 276
    Re: 2080 ti kingpin power draw issues 2019/04/12 21:55:51 (permalink)
    Not understanding this as your card Target is set to Zero yet it shows 489%
    You should do a Clean up of your Computer.
    Remove MSI Afterburner.
    Remove PX1 and delete all the Folders, make sure you remove the on under your Profile
    Uninstall all the NIVIDIA Software and Drivers, DO NOT RESTART
    Remove the Network from your Computer
    Run DDU and tell it to Start in Safe Mode and the let it Restart Your Computer
    Clean up with DDU restart
    Install the NVIDIA Drivers Graphics and PhysX Only
    Restart the Computer
    Connect the Network back to your Computer
    Run Windows Updates
    Install PX1 Version 0.3.14.0 BETA https://www.evga.com/precisionx1/
    post edited by bcavnaugh - 2019/04/12 22:01:36
    Jahusaphet
    Re: 2080 ti kingpin power draw issues 2019/04/12 21:56:57 (permalink)
    Hardware: 6800k 4.4 ghz
    Evga Classified ftw K
    Evga supernova 1200 p2 (old and seemingly Broken PSU)
    Evga 750 g2 (one I'm using to test each card)
    2080 ti kingpin X2 (one is reporting 850-1500w power draw and the other is running fine)
    Both cards have been tested independently. One is stuck at 300mhz while reporting 850 -1500w and the other works perfectly.
    Jahusaphet
    Re: 2080 ti kingpin power draw issues 2019/04/12 22:00:05 (permalink)
    This card is stuck on 300hz even when it's running by itself.
    degenerate
    Re: 2080 ti kingpin power draw issues 2019/04/12 22:03:10 (permalink)
    Jahusaphet
    Something strange if GPU-Z is reporting 1500w.... you've never touched the Classified Tool? Change Power Management to Adaptive, generally the best setting, reboot after changing.
    What happens when you put a load on the one you say is stuck at 300mhz? Does it boost or actually stick at 300mhz?
    • Ribbons : 276
    Re: 2080 ti kingpin power draw issues 2019/04/12 22:04:12 (permalink)
    Jahusaphet
    Run with ONE Card in the PCIe Slot Next to the CPU
    Test Each Card on your Computer REMOVE the Second Card.
    It could be your NVLINK SLI Bridge.
    Use One Card and One Power Supply.
    Jahusaphet
    Re: 2080 ti kingpin power draw issues 2019/04/12 22:05:11 (permalink)
    It stays at 300 mhz because it thinks its power limited. I've never touched the classified tool yet. Havent really had a chance.
    • Ribbons : 276
    Re: 2080 ti kingpin power draw issues 2019/04/12 22:08:06 (permalink)
    Is your Motherboard Bios Up To Date?
    Did you Reset the Bios between changing Cards?
    Last Do Not Overclock your CPU and Memory on the Motherboard, Keep them at Auto to test your Graphics Cards.
    Jahusaphet
    Re: 2080 ti kingpin power draw issues 2019/04/12 22:08:36 (permalink)
    Jahusaphet
    okay, I'm sorry are you reading what I've said, each card has been tested independently with the 750g because the 1200 p2 does not work anymore. The card with the higher power draw has been tested with the latest and previous nvidia drivers and I've tried the normal and PC bios. Neither seems to change anything.
    The other card works fine. Has no issues. I no longer have them in sli. And the card IS STUCK at 300mhz, no matter what load I put it under it never changes. I know the card isnt actually drawing this much power because its 27°C.
    • Ribbons : 276
    Re: 2080 ti kingpin power draw issues 2019/04/12 22:12:22 (permalink)
    Do Not Go by what the OLED shows only because mine show 1% Usage and the card is running at 97%
    Mine shows 1350MHz and never changes on the OLED even though it is really running @ 2175 MHz.
    This does make it a little Clearer. I have to of read it 20 Times now so Yes I am Reading what you have Posted.
    "okay, I'm sorry are you reading what I've said, each card has been tested independently with the 750g because the 1200 p2 does not work anymore."
    "Evga Classified ftw K." Not sure what Motherboard this is?
    They are two different Motherboards.
    X99 Classified 151-HE-E999-KR
    X99 FTW K, 151-BE-E097-KR
    Your CPU only has 28 PCI Express Lanes
    https://ark.intel.com/content/www/us/en/ark/products/94189/intel-core-i7-6800k-processor-15m-cache-up-to-3-60-ghz.html
    I would get the EVGA 1600 Watt Power Supply for two cards or Two Power Supplies a 850 Watt for the Motherboard and a 1200 for the Graphics Cards.
    post edited by bcavnaugh - 2019/04/12 22:24:33
    Jahusaphet
    Re: 2080 ti kingpin power draw issues 2019/04/12 22:40:59 (permalink)
    its the FTW K and even if I need a better PSU why is one card now not working correctly and the other is? They've both been tested. Next will be DDU and clean slate and such but it seems one card has started having a malfunction. And while I understand that the cpu only has 28 lanes I dont understand what that has to do with the cards issues. Even using 16 lanes independent of the other card it's still having this issue.
    • Ribbons : 276
    Re: 2080 ti kingpin power draw issues 2019/04/12 23:04:23 (permalink)
    As you said above you have a bad card and need to RMA it, as to why only EVGA can tell you.
    You only need 8 Lanes Per GPU to run SLI.
    Have you updated the Chipset Driver on your Computer?
    Intel® Chipset Driver for Windows Version: 10.1.17969.8134 (Latest)
    I have both Motherboard and installed the Chipset Drivers on Both as well as my X299 Dark and FTW and Z370 FTW Motherboards.
    post edited by bcavnaugh - 2019/04/12 23:08:06
    Jahusaphet
    Re: 2080 ti kingpin power draw issues 2019/04/12 23:48:42 (permalink)
    I will try that next, doing a clean install of drivers as you suggested earlier. Moved to a 7700k system I have.
    Jahusaphet
    Re: 2080 ti kingpin power draw issues 2019/04/12 23:50:50 (permalink)
    a lot thanks for your help, I know its late.
    #23
    TiN_EE
    • Ribbons : 13
    Re: 2080 ti kingpin power draw issues 2019/04/13 04:05:51 (permalink)
    I'd suggest to contact support for RMA, if card is always stuck at 300MHz low P-state, as that is likely hw problem.
    #24
    dc8flyer
    Re: 2080 ti kingpin power draw issues 2019/04/13 07:22:02 (permalink)
    You have not mentioned which PX1 you are running. Post 11 has the link for the current PX1.
    Px1 03.14.0 was released shortly after 03.13.1. Perhaps the update will work better and correct your issue.
    2009 Alienware Aurora x58
    i7 990x oc to 4.14
    Three ASUS ROG PG278Q Black 27" WQHD 2560 x 1440 - 144 Hz 1ms (GTG) NVIDIA G-Sync Gaming Monitors
    RTX 2080ti EVGA Black XC oc 1100/150
    CORSAIR Vengeance 24GB (6 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 memory
    2TB 860evo SSD
    Corsair Hydro Series H80i V2 Water/Liquid CPU Cooler
    Two 120mm push/pull NF-F12 iPPC-3000 PWM Fan with Focused Flow
    #25
    andrewrocks
    Re: 2080 ti kingpin power draw issues 2019/04/13 12:03:49 (permalink)
    why is your voltage so high? can you lower it?
    #26
    Jahusaphet
    Re: 2080 ti kingpin power draw issues 2019/04/13 13:20:11 (permalink)
    dc8flyer
    Its PX 03.14.0
    #27
    sparetimepc
    • Ribbons : 8
    Re: 2080 ti kingpin power draw issues 2019/04/14 18:11:00 (permalink)
    Run Windows Updates
    So in sli when you show this stuck at 300 and the wattage of 857 is the card that is showing this card #2 in your px1 ?   If so mine is doing the same thing.
    Click the bottom code for a 5% to 10% discount on your purchases.
    #28
    Jahusaphet
    Re: 2080 ti kingpin power draw issues 2019/04/14 18:14:22 (permalink)
    dwexpress
    Run Windows Updates
    were you able to fix this? And yes it was, but now it is doing it independently.
    #29
    sparetimepc
    • Ribbons : 8
    Re: 2080 ti kingpin power draw issues 2019/04/14 18:18:23 (permalink)
    Have not fixed it, just noticed the issue and not enough time to figure it out yet.
    #30
