2080 ti kingpin power draw issues
Jahusaphet
Re: 2080 ti kingpin power draw issues 2019/04/14 18:24:17 (permalink)
Okay, please keep me updated. Maybe I shouldn't put my replacement card in when. It arrives.
#31
sparetimepc
  • Ribbons : 27
Re: 2080 ti kingpin power draw issues 2019/04/14 18:34:42 (permalink)
Have you already RMA'd yours then?
#32
sparetimepc
  • Ribbons : 27
Re: 2080 ti kingpin power draw issues 2019/04/14 18:38:51 (permalink)
Yeah it looks like one of mine is defective as well, when running benchmarks pxi and gpuz both show the one card is stuck at 300mhz
I saved the oc bios to file from the good card and then did a reflash to the defective card and it didn't change anything.
post edited by dwexpress - 2019/04/14 18:44:13
Jahusaphet
Re: 2080 ti kingpin power draw issues 2019/04/14 18:47:46 (permalink)
dwexpress
I called technical support. They got told me it seemed like a hardware issue. It looks like they are having issues with sli. I have no confirmation of that and 2 does not make a pattern. Guess we'll have to see as more people start recieving their cards.
#34
sparetimepc
  • Ribbons : 27
Re: 2080 ti kingpin power draw issues 2019/04/15 05:28:41 (permalink)
So what motherboard are you using and what nvlink brand? Also i was able to use each card individually and they work fine, but when reversing them the same problem occurs, its always the card in the bottom slot. I guess make sure your cards are fine as individuals before thinking one is bad and then reverse them to see if its the same problem, always in the bottom slot where the card is not right. If it acts the same way on yours its either a kingpin in sli configuration issue or a different hardware issue.
#35
Jahusaphet
Re: 2080 ti kingpin power draw issues 2019/04/15 06:42:03 (permalink)
dwexpress
I'm using an evga sli nvlink bridge and an evga motherboard. The bottom card is the one that messed up, but after removing them from SLI the bottom one is stuck at the 300mhz and 800+ power draw.
#36
sparetimepc
  • Ribbons : 27
Re: 2080 ti kingpin power draw issues 2019/04/15 06:44:42 (permalink)
Did you just remove them from SLI by taking off the nvlink bridge but leave them both installed? Or did you remove them  both completely and try them individually and still determine the one is stuck? I am using the Asus Nvlink and Asus board.
#37
Jahusaphet
Re: 2080 ti kingpin power draw issues 2019/04/15 06:46:03 (permalink)
Removed completely the tested each one.
#38
sparetimepc
  • Ribbons : 27
Re: 2080 ti kingpin power draw issues 2019/04/15 06:50:46 (permalink)
Jahusaphet
OK, your issue is different then mine then it seems because each of mine individually work fine, but in SLI which ever is in the bottom slot is where the stuck at 300mhz occurs.
#39
KonaChan
Re: 2080 ti kingpin power draw issues 2019/04/15 11:55:33 (permalink)
posted by accident, my b
post edited by KonaChan - 2019/04/15 15:26:45
#40
Jahusaphet
Re: 2080 ti kingpin power draw issues 2019/04/15 12:39:13 (permalink)
KonaChan
any1 have guestimate for when more KP's will be in stock?
not in this thread
#41
EVGA_JacobF
  • Ribbons : 26
Re: 2080 ti kingpin power draw issues 2019/04/15 16:43:04 (permalink)
This looks to be firmware/software related. We are working on it and will keep you posted.
#42
EVGA_JacobF
  • Ribbons : 26
Re: 2080 ti kingpin power draw issues 2019/04/15 16:47:04 (permalink)
Also which BIOS are you guys using?
#43
Vlada011
  • Ribbons : 11
Re: 2080 ti kingpin power draw issues 2019/04/15 16:55:01 (permalink)
Definitely looking total picture...
PCB, build quality, cooling, software, design, package,... EVGA RTX2080Ti K|NGP|N is most advanced GPU ever build.
And for real enthusiasts finding and buying this GPU is ultimate task.
http://www.evga.com
http://www.intel.com
http://www.nvidia.com
https://watercool.de
http://www.lian-li.com
#44
sparetimepc
  • Ribbons : 27
Re: 2080 ti kingpin power draw issues 2019/04/15 17:00:57 (permalink)
EVGA_JacobF
I am on the OC bios but i switched over to the normal bios as well and tried it but the same issue was there.
#45
AHowes
  • Ribbons : 27
Re: 2080 ti kingpin power draw issues 2019/04/15 17:57:31 (permalink)
dwexpress
EVGA_JacobF
Are you sure it swapped? I know it can be a pain to change bios. Sometimes you need to totally kill power to the card.. pull the psu plug from the back of the case and hold the power button in for 15 secs to full drain the caps on the motherboard to fully drain the power.
Then flip the bios switch and power up.
Asus Z390 ROG Extreme XI MB
#46
sparetimepc
  • Ribbons : 27
Re: 2080 ti kingpin power draw issues 2019/04/15 18:15:18 (permalink)
AHowes
dwexpress
EVGA_JacobF
Yes done that. The bios led switched colors as well.
#47
Jahusaphet
Re: 2080 ti kingpin power draw issues 2019/04/15 18:36:29 (permalink)
EVGA_JacobF
Tried all three, but happened while I was using OC.
#48
sparetimepc
  • Ribbons : 27
Re: 2080 ti kingpin power draw issues 2019/04/16 08:04:31 (permalink)
Installed a new Asus Nvlink and problem solved, working like a charm now.
#49
AHowes
  • Ribbons : 27
Re: 2080 ti kingpin power draw issues 2019/04/16 08:32:24 (permalink)
dwexpress
Awesome!
#50
EVGA_JacobF
  • Ribbons : 26
Re: 2080 ti kingpin power draw issues 2019/04/16 09:21:04 (permalink)
There is a new version of PX1 that fixes this issue:
https://www.evga.com/precisionx1/
#51
  • Ribbons : 282
Re: 2080 ti kingpin power draw issues 2019/04/16 09:30:29 (permalink)
EVGA_JacobF
Thank you EVGA_JacobF
Pump RPM still shows 0 on the OLED.
post edited by bcavnaugh - 2019/04/16 10:19:15
#52
Jahusaphet
Re: 2080 ti kingpin power draw issues 2019/04/16 09:39:15 (permalink)
EVGA_JacobF
I'll try this with my kingpins to see if it fixes it.
#53
GTXJackBauer
  • Ribbons : 48
Re: 2080 ti kingpin power draw issues 2019/04/16 10:19:33 (permalink)
dwexpress
That is the baddest looking bridge I've ever seen.
LMD3DNZM9LGK8GJ
#54
sparetimepc
  • Ribbons : 27
Re: 2080 ti kingpin power draw issues 2019/04/16 10:25:28 (permalink)
GTXJackBauer
dwexpress
Its for sure a pretty thing, kind of like mirrored layers within, its awesome.
#55
Jahusaphet
Re: 2080 ti kingpin power draw issues 2019/04/16 20:04:28 (permalink)
So now my bottom card (broken one), is showing correct wattage in PX1 but is saying 485% power draw still.
#56
bjmaguire
Re: 2080 ti kingpin power draw issues 2021/03/19 16:38:42 (permalink)
My card is doing the same thing...EVGA 2080ti is a lemmon
#57
