Yes the pump and fan should be drawing from the power limit as the current draw is measured at the +12V inputs (current sense chip monitors the 2x PCIe cables and the PCIe slot).
Pump and fan both have their wattage printed on the stickers. They're about 7.7W together if I remember correctly (pump drawing 7.5W of that).
Both the pump and fan both run at full speed all the time.
The blower fan for the VRM's is controlled by the card. The other stuff; pump/fan steal the +12V from that fan connector.
If you want to connect the pump/fan elsewhere your options are:
• Leave pump connected to card and connect the fan to MB header (IMO pointless as the pump draws most of the power).
• Use a different pump that gets connected to the MB/PS and only grab (I.e. Unscrew) the adapter plate from the one that comes in the EVGA box.
• Make/buy adapter cables to connect the pump/fan to the MB/PS.
• Make a adapter for
only the fan that steals the PWM signal from the GPU. -- This will give you software control (30%-100%) of whatever PWM fan you attach. -- Also somewhat pointless, but does have some advantages.
• Desolder the stock cables and solder your own (the pads aren't too small and you can even add a tachometer wire), then connect it to your MB/PS
• Solder stock power input cable directly to the 8pin +12V and GND. -- Risky for the card but then you can tuck the cable inside the shroud. I SERIOUSLY don't recommend this one.
Note: With any of these you can replace the fan too. Keep in mind that the default pump connector is 2-pin (no PWM or Tach.).
Any soldering done to the pump or card will void EVGA's warranty! Anything that doesn't involve soldering or connecting crap the wrong way is fine provided you can return the items to stock condition before doing a RMA.
post edited by Quad5Ny - 2017/05/24 11:58:22
