Re: 1080TI FTW3 Open Loop Water Cooling
2017/05/23 02:45:07
iiMStevo
So I'm looking to get the 1080TI FTW3, but I'm also really considering setting up an open-loop water cooling rig too.
I'm a little torn between what I should get and what I want to get...
For example, the 1080TI FTW3 comes with the ICX cooler (which will be removed) and a second BIOS chip, and extra power, but is any of that needed if I'm stripping off the ICX cooler in a few months? Would I be better off getting the founders edition 1080 TI, and removing the cooler from that to fit a 1080TI Water block?
Has anyone else got an open-loop water cooling setup?
if you're looking to water cool a GTX 1080Ti I would personally just get a FE, slap a block on it and go to town. There's no need to waste money on the FTW3 due to Pascal being very limited in terms of OC/voltage etc.
CPU: Intel i7 4790k @ 4.8ghz
MOBO: Asus Z97 PRO WIFI-AC
GPU: EVGA GTX 1080Ti FTW3
RAM/Memory: 16GB Kingston HyperX 1866Mhz
HDD 1: 512GB Crucial SSD- OS
HDD 2: 4TB HGST- storage
HDD 3: 2TB Hitachi- more storage
PSU: EVGA SUPERNOVA 850 G2
CASE: Corsair 760T (Arctic White)
OS: Windows 10 Pro 64 Bit
