Pepp11
Hello my friends, I am new here. So first things first. My name is Pepp and I am from germany. I own the 1080 ti ftw3 for ~5 month now and overall I'm very happy with that card. The first time this card worked perfectly but since 2-3 weeks one of the fans is going crazy. For example, if I play csgo, two of the fans start to spin (everything is fine) but then the 3rd fan starts and is super loud and fast. This goes one for about 5min, then the 3rd fan slows down. Just to go crazy again after another 10min or so and so on. I have installed a fresh windows and the newest driver from Nvidia, but nothing changed. I have downloaded the precision XOC to see the rpm of the 3 fans (see picture). My questions are, is that a common thing and do I only need to change the 3 fan curves or not? I am not that experienced with doing that. And why does that only appear since 2-3 weeks? I just dont know what the problem is. :) I am playing on 1440p. My system: Win 10 64 bit Mainboard: Asus ROG Maximus Hero X CPU: Intel Core i7 8700k GPU: EVGA 1080 ti ftw3 RAM: 16 gb Best regards Pepp
post edited by Pepp11 - 2018/11/10 13:42:42
Re: 1080 ti ftw3 high fan speed
2018/11/10 13:43:43
When the fan goes crazy can you slow it down using precision?
Pepp11
2018/11/10 14:27:03
Hi, yes i can slow it down with the controller if its going crazy. Then there is said 0rpm but I can tell you that this fan is definitely spinning
2018/11/10 14:35:33
Does the issue occur with precision xoc uninstalled from the system? Have you inspected the card to make sure all the fan cables are fully seated to their respective fan headers?
Pepp11
2018/11/10 15:08:31
1) Does the issue occur with precision xoc uninstalled from the system? Yes it does. Thats why I installed it in first place, to see what the problem is. 2) Have you inspected the card to make sure all the fan cables are fully seated to their respective fan headers? Atleast now I did. And nothing changed.
2018/11/10 16:43:25
Can you test the card in another machine to see if you can replicate the issue in another system?
Pepp11
2018/11/11 03:49:19
Sadly that's not possible for me.
2018/11/11 14:03:05
Ok, does the issue occur on the secondary vbios as well?
Pepp11
2018/11/12 09:46:44
Are you talking about that switch from normal --> oc ? If so, then yes it still occurs.
2018/11/12 14:10:16
Yep, that is what I was talking about. I'd recommend taking the card to a local pc shop to see if they can reproduce the issue before rma'ing the card.
Pepp11
2018/11/14 09:04:45
Hello again, so I've tested it now in another system and it still occurs... Best regards, Pepp
2018/11/14 11:36:07
☼ Best Answerby Pepp11 2018/11/14 11:49:18
Pepp11
2018/11/14 11:49:12
I really hate to do it. But thank you for your help. Bye
2018/11/14 11:52:21
