Re: 1080 Ti ftw 3 hydro copper Power Target issue
2018/05/16 19:59:48
Like I said... setting the voltage slider to max doesn't actually force the card to use the max voltage. Adjusting the voltage slider to max only allows the card to use more voltage. If you want to force the card to run at max voltage you need to do what I listed in my oc guide.
Slider6996
2018/05/16 20:17:26
hm does precision have that voltage curve editor cause the short cut keys dont seem to apply to presicion or im brain farting. EDIT: Nvm im stupid....what i get for skipping end of a sentence on ur guide lol.
post edited by Slider6996 - 2018/05/16 20:20:18
Dell s2716dg Gsync 144hz Main gaming monitor Asus 60 Mhz 2nd Monitor Intel i7-7820X OC 4.7 Ghz Custom Water loop Evga 1080ti hydro copper GSkill Trident RBG 16gb Ram X299 MSI x299 M7 ACK Motherboard Sound Blaster Z Soundcard Steel Series Artic 7 Headset Razer Chroma Keyboard Evga 750 Watt PSU Corex71 Full Tower Case
2018/05/16 20:19:24
Yes, but it doesn't work correctly. You'll need to use msi afterburner.
Slider6996
2018/05/16 20:20:33
ya i just edited cause caught my boo boo lol.
Slider6996
2018/05/16 20:43:04
hm following guide and i get to where i do the yellow line but i dont see a white type line going across and two my voltage stays the same and dont go up like in screenshots, but ya i dont see that straight white line going across, just the curve.
post edited by Slider6996 - 2018/05/16 20:45:26
2018/05/16 20:54:14
Here is the next step after you get the yellow line up... #7 Press the check mark button on the main gui to apply your changes. Your card should now be running at a fixed frequency/voltage, and your curve should look like figure 5.
Slider6996
2018/05/16 20:55:53
ya i think i got what it meant from description and pictures but there seems to be a issue regardless, my gpu no longer upclocks, it stays locked at them frequencys in pic. it dont downclock or upclock and no voltage increase lol, so not sure what i did. Dont see how i could of made it stay locked on speeds
2018/05/16 20:56:38
It's suppose to be like that. Continue the guide.
Slider6996
2018/05/16 21:06:38
gawd windows sucks sometimes, now i have the same lines as in pictures, i had to restart pc cause gpu was like legit stuck at low frequencies like the idle ones, now it makes more sense since my graph now looks like yours, all i had was the yellow line, i never had the white so gonna get back to trying again now.
2018/05/16 21:07:39
Slider6996
2018/05/16 21:17:46
So do u accept sexual favors lol? Cause uh...i just broke 2100 for first time on card and almost got 25k on 3dmark.....
2018/05/16 21:18:21
Slider6996
2018/05/16 21:19:34
Muchly appreciate the help, just one final question now, is there a way to get the clocks to downclock like normal still? Im sure it dont hurt the card staying at those when idle just curious if there a way to enable a downclock still possibly.
2018/05/16 21:27:40
Simply open the voltage/frequency curve editor and press ctrl+l to make the yellow line go away. Then click the check mark button on the main gui to make the card downclock at idle.
Slider6996
2018/05/16 21:33:32
Alright cool ty. I didnt even touch memory clock yet but this is what im getting so far. Thats crazy precision dont allow this kinda tweaking, guess im sticking with msi for now. Ty again :)
2018/05/16 21:34:12
Lookin good.
Slider6996
2018/05/16 21:35:45
Alright well ty again :) didnt even know something could be done like that so good to know, gonna go work on final fantasy 15 now lol, ty again man.
2018/05/16 21:36:25
No problem.
Slider6996
2018/05/17 15:11:30
Hey Sajin i just noticed something ( something good ) i started up tomb raider to check something in game and i forgot to re enable the Ctl L to enable that yellow line but i was curious what would happen if i didnt so got in game and loaded save and i still get same clocks and even my voltage goes to max to maintain overclock without even having to use the ctl L in msi. I assumed i had to do that to make the card use that voltage but seems i dont? So seems like perfect scenario and just made me for sure stick with msi AB over precision. Gotta go do some RL stuff for awhile but figure let u know.
2018/05/17 16:01:58
Slider6996
2018/05/17 17:58:31
back now but ya clocks can downclock normally now and still get max boost from card and clocks so im happy :)
2018/05/17 18:13:06
