Update, solved for now, post #10
TLDR: upgraded thermal pads to GELID Extreme, board temps dropped 10 degrees and became uniform across board, stability increased, OC headroom increased, etc.
So far it only occurs in Borderlands 3 when it's graphically maxed out in game settings w/1440p res.
My frame rate drops from 120 FPS to 20-30 FPS.
Graphs show short game play, then sudden Power & FB drop to ~50%, then I leave the game a few moments later.
Other things of note:
- GPU & mem clocks do
not drop! They stay full speed despite the change in power.
- FB/Frame buffer drops 50% with the power drop.
- Temps always in range but cool off slightly
I have to restart the PC to fix the issue but usually comes back pretty quickly the next time I play Borderlands 3. Restarting the game alone does not work.
I have latest drivers for everything, DDU in safe mode etc.
Windows 10
AMD 3950X
1080 TI KPE
32gb 3733 16 cas ram
Asus x570 Impact mobo
CORSAIR SF750 Platinum PSU
Samsung nvme pro raid 0.
post edited by _Gir_ - 2020/05/22 00:01:00
