marcusds
Just like the title says, 1070 FTW LED customization not working in Precision X1. Works in LED sync, but not the main app. Is there any way to fix this?
12G-P5-3967-KR 6/3/2021 7:46:35 AM PT No 12G-P5-3953-KR 6/30/2021 6:36:14 AM PT No 10G-P5-3895-KR 10/10/2020 8:42:53 AM PT No 10G-P5-3897-KR 10/10/2020 8:42:38 AM PT No (I was an idiot and turned off the email notify before they switched to the new system)
alfont
Re: 1070 FTW LED customization not working in Precision X1
2020/01/02 16:01:53
Precision X1 only the 2000 series
- Ribbons : 270
2020/01/02 20:31:22
Use Precision XOC for cards before RTX.
Ghost13
2020/01/03 00:32:43
Precision X1 is the newest, it not only works for the newer cards, but will work with the 1000 series as well .. mine works just fine .. im running the same 1070ftw . my RGB lights are set to white, my cpu is set to blue and my 1070FTW is set to a pinkish color , the rgb lights are running off the DG-77 case i have and the 1070FTW is running off the Precision X1, there are tabs on the right side of the program once it is opened .. they are OSD HWM LED XOC Boost click on the tab a little blue light type thing will show up for on or off .. https://www.evga.com/precisionx1/ the tabs on the right side, make sure that the LED tab is clicked to were the blue light shows ..
post edited by Ghost13 - 2020/01/03 00:40:24
Matthias14
2020/03/25 16:37:27
Hello, I am reviving this thread since I encounter almost the same Problem, although the X1 Apllication does not even offer me the LED Tab. I have the latest BIOS installed and the Latest NVidia drivers aswell. I have just set up a fresh Win 10 64bit and was using X1 for the first time, I only uses XOC before where the LED controls were working fine for me.
2020/03/25 16:55:42
Matthias14 Hello, I am reviving this thread since I encounter almost the same Problem, although the X1 Apllication does not even offer me the LED Tab. I have the latest BIOS installed and the Latest NVidia drivers aswell. I have just set up a fresh Win 10 64bit and was using X1 for the first time, I only uses XOC before where the LED controls were working fine for me.
post released from filter - sorry for the delay
Matthias14
2020/03/26 04:43:21
Pardon? I have now Installed the X1 Version 1.02 and the Tab for the LED control appeared, but still any changes I make take no effect. The LED tab also displays a layout as If I had an SLI layout wich I don´t, I tried to apply changes in every combination possible but none take effect. Will this be fixed or shall I just go back to OG XOC?
2020/03/26 07:33:09
Matthias14 Pardon? I have now Installed the X1 Version 1.02 and the Tab for the LED control appeared, but still any changes I make take no effect. The LED tab also displays a layout as If I had an SLI layout wich I don´t, I tried to apply changes in every combination possible but none take effect. Will this be fixed or shall I just go back to OG XOC?
EVGA Precision X OC if you want all the previous feature for LED control ... seems to be the only "fix" @ this time
Matthias14
2020/03/28 06:17:07
python
2020/04/05 03:56:41
when u game do u look at ur pc? or play the game..oh look i have pretty colors inside my pc case..who gives a crap? never understood why people would even be concerned with it..function over form
objective to reach 16k posts 9700k @5.0ghz asus z390 hero xi Nvidia 4070 thermalright silver arrow sb-e EVGA SUPERNOVA 1000 PS
- Ribbons : 135
2020/04/05 10:21:04
python when u game do u look at ur pc? or play the game..oh look i have pretty colors inside my pc case..who gives a crap? never understood why people would even be concerned with it..function over form
I don't know why folks get enraged over what other folks do for a hobby. Bad form over function would describe your post.
python
2020/04/06 05:51:24
enraged? lmfao..ok mr 14k posts..get a life dude
- Ribbons : 135
2020/04/06 11:46:02
python
I have one, which is why minor things like a post on a forum don't send me off the rails. Perhaps it is good you don't post that much. Apparently you find it upsetting. I guess I am too hyper with an average of 3 posts a day. I used to be more active, but too many folks like you around.
python
2020/04/10 06:52:56
python
lol..specious logic at best..so u dont post more because of people like me? thanks man i needed that laugh..carry on
siemenscs
2021/01/15 17:30:25
there is an app installed on your computer called "LEDSync.exe" find it run it and the led settings are on that. I have a 1070ftw and precision x1 does not control it.
