!070 ti SC Hybrid Overheating and Another 8 Pin Power Connector Failed
Chai67
2018/05/16 09:40:05 (permalink)
Something's wrong with the 1070 ti SC Hybrids. One had the 8-Pin power connector fail which is being RMA'd. Now another one has a failing AIO pump causing the GPU temperature to start at 44C (usually 33C) and kick up to 94C when gaming. Is there any way to troubleshoot this AIO pump issue?
10 Replies Related Threads
    • Ribbons : 189
    Re: !070 ti SC Hybrid Overheating and Another 8 Pin Power Connector Failed 2018/05/16 10:26:55 (permalink)
    If you don't feel any vibration when touching the tubes the pump isn't working.
    • Ribbons : 91
    Re: !070 ti SC Hybrid Overheating and Another 8 Pin Power Connector Failed 2018/05/16 11:13:33 (permalink)
    +1
    also, one tube should be warmer than the other
    did you mount it above GPU with hoses on bottom of radiator ?
    RTX Project EVGA X99 FTW-K-5930K, 2-EVGA2080Ti, EVGA 1200P2
    Rig-2 AIO Folding  X99-5930K 2-1080Ti FTW3 Hybrid, EVGA-1200P2
    Rig-3 Nibbler EVGA X99 Classy-5960X 3GPU H2O 4K Acer-XB280HK  Folding@EVGA
    Chai67
    Re: !070 ti SC Hybrid Overheating and Another 8 Pin Power Connector Failed 2018/05/16 16:27:10 (permalink)
    +1
    This one's mounted on top vent. The radiator is horizontal.
    I did not see nvidia-smi come with the latest driver for pulling fan info and not sure if the CUDA toolkit will be of any use.
    fetterEsel
    Re: !070 ti SC Hybrid Overheating and Another 8 Pin Power Connector Failed 2018/05/16 18:07:41 (permalink)
    Should’ve gotten an air cooled card... have fun replacing your card every few months due to a dead pump though.
    Chai67
    Re: !070 ti SC Hybrid Overheating and Another 8 Pin Power Connector Failed 2018/05/16 18:24:12 (permalink)
    My other rig with non-ti Hybrids have run for over a year with no issues.
    Chai67
    Re: !070 ti SC Hybrid Overheating and Another 8 Pin Power Connector Failed 2018/05/16 21:07:50 (permalink)
    The problem may have been a bad power cable. Swapped it out and now this one's back to normal operation.
    jfw06013
    Re: !070 ti SC Hybrid Overheating and Another 8 Pin Power Connector Failed 2018/05/16 22:25:01 (permalink)
    I have a EVGA 1080 Hybrid that I bought in 12/23/2016 and crunching [link=mailto:seti@home]seti@home[/link] 24/7 (overclocked) using EVGA Precision XOC with no problems.
    Chai67
    Re: !070 ti SC Hybrid Overheating and Another 8 Pin Power Connector Failed 2018/05/17 00:31:14 (permalink)
    jfw06013
    I have a EVGA 1080 Hybrid that I bought in 12/23/2016 and crunching 24/7 (overclocked) using EVGA Precision XOC with no problems.
    I ran a 4870 for SETI way back when. So glad to hear they're still working on that project.
    • Ribbons : 91
    Re: !070 ti SC Hybrid Overheating and Another 8 Pin Power Connector Failed 2018/05/17 08:33:01 (permalink)
    Chai67
    Glad it was only a power cable issue
    Thanks for the update
    • Ribbons : 189
    Re: !070 ti SC Hybrid Overheating and Another 8 Pin Power Connector Failed 2018/05/17 13:31:04 (permalink)
    Chai67
    Hopefully it isn't a pump that runs intermittently.
