x99 classy EK D5 PWM pump low flow rate.
sputnik7913
2016/11/21 15:56:39 (permalink)
 I have purchased an EK D5 PWM pump and connected it to CPU fan 4-pin connector on the board... When I set maximum pump speed (100%) in bios, it only runs at 3400rpm, as opposed to 4800rpm of pumps maximum speed... Any ideas folks?
3 Replies Related Threads
    GTXJackBauer
    • Ribbons : 10
    Re: x99 classy EK D5 PWM pump low flow rate. 2016/11/21 16:08:18 (permalink)
    AFAIK, the original PWM D5s aren't following the intel standard but their G2 (Generation2) do.  I believe if this is the case, your pump is only running at 60%.  You could look for something called the "Diva Mod" from OCN forums.
    sputnik7913
    Re: x99 classy EK D5 PWM pump low flow rate. 2016/11/21 16:14:50 (permalink)
    GTXJackBauer
    OMG..... i'm a big fan of modding, but this is way out of my field ... You have any links to that G2 pump? I can't find it...
    post edited by sputnik7913 - 2016/11/21 17:22:04
    LazySoft
    Re: x99 classy EK D5 PWM pump low flow rate. 2016/11/21 20:46:30 (permalink)
    Try another PWN fan header than CPU. It seems that will be better. or try to make a Diva fix.
    Lazy or not Lazy. That's not a question.
