yapchagi
Re:first GTX 670 waterblock
Friday, July 13, 2012 8:00 AM
here's my GTX 670 4 GB SC with EK-FC 670 waterblock. I messed up the fittings, so I need to order some more parts. I was gonna connect the 2 cards via that 90-degree barb (one facing down, one facing up) and connect the two with 3/8" ID tubing, but the distance between them is too short. So I need to rethink my setup again. In the meantime, I connect both cards with whatever way I can with whatever I have and I think I may need to upgrade my pump too. Currently my pump is 800 LPH. I'm also watercooling my CPU. The problem is the flow-meter is not moving at all. So either the flow-meter is broken or the flow is just really slow. So I'm not sure if I should upgrade my pump. It's like spending another $120 - $130  I'm using this flow-meter. Is it possible for that flow-meter to stop turning? Like it's broken maybe. Thinking about changing it into this one. What do u guys think?
post edited by yapchagi - Friday, July 13, 2012 8:13 AM
Reglar
Friday, July 13, 2012 6:22 PM
What did the flow meter show before you added the GPU blocks to your loop, or is this a new loop? If it's a new loop, do you have the correct additional hardware to convert the flowmeter results to something a motherboard header can read, or did you hook it up to something else? When you bled the loop of air, was your pump doing a good job of pushing the air out of the blocks or was it a hassle to bleed?
yapchagi
Friday, July 13, 2012 10:47 PM
Reglar What did the flow meter show before you added the GPU blocks to your loop, or is this a new loop? If it's a new loop, do you have the correct additional hardware to convert the flowmeter results to something a motherboard header can read, or did you hook it up to something else? When you bled the loop of air, was your pump doing a good job of pushing the air out of the blocks or was it a hassle to bleed? It's not a new loop. I've been using the flow meter for about 2 years maybe. It worked just fine. Then I sold the 680 HC about 2 months ago and used the whole watercooling for the CPU only and the flow-meter was rotating slower. I'm thinking either the pump gets weaker or something is blocking the flow inside. So yesterday I added 2x GTX 670 with EK-FC670 waterblocks in the loop. I could see air bubbles in the tube yesterday and the pump was having a hard time pushing it through the tube. Anyway for temperature results...using a 360 rad + pump 800 LPH + 3/8" ID tubing. Cooling CPU + 2x GTX 670 EK-FC670 waterblocks. Right now CPU idles at 41c, both GPUs at 34C. Yesterday I ran Heaven 3.0 and GPU #1 reached 50c, GPU #2 reached 47c. This is with the flow-meter not showing any flow at all.
loveha
- Ribbons : 65
Friday, July 13, 2012 11:13 PM
I don't run flow meters. Waste of money in my opinion. My flow meter is seeing if the water is moving in my reservoir. Recommend Watercool for water blocks (Company that makes Heatkiller Blocks). You can order direct from them and they will ship anywhere in the world. That is what I did to get exactly what I want. No one had the Nickel GTX680 block with backplate from them. Customer service kind of took me by surprise when I had orderd two blocks but one backplate. They actually emailed me asking if it was mistake. Said if it was or if I would like to I can paypal them directly and they will add the second one to my order. They also took the time to confirm if the SLI Bridge was the right spacing to work with my motherboard. They have my service from now on. EK lost my service with the new design.
Case - Phanteks Enthoo Evolv XMobo - EVGA X570 FTWCPU - AMD Ryzen 9 5900XRAM - 32GB Trident Z Royal 3600MHz 14-14-14-34GPU - EVGA RTX 3080 Ti FTW3 Ultra GamingPSU - Seasonic Prime TX-1000Heatkiller IV CPU Waterblock / Heatkiller V GPU WaterblockHeatkiller V EBC Active Backplate / Two Heatkiller Rad 360 L Six Noctua NF-A12x25 / Heatkiller D5 Pump
eternitykh
Friday, July 13, 2012 11:14 PM
with those temps, your pump is working correctly, your flow-meter is probably going bad.
Core i7-3770k De-Lidded @ 4.8ghz // Asus Sabertooth z77 // Corsair Vengeance Black 1866mhz 9-10-9-27 4x4GB DDR3 2x EVGA GTX 670 FTW+ 4GB SLI // 3x Asus VH238H Monitor in Surround // Asus Xonar DX7.1 Sound Card Corsair Obsidian 700D Chassis // Corsair AX850 PSU // Corsair Neutron 240 SSD Corsair Individually sleeved Modular Cables // Custom Black Rigid 2-way SLI bridge XSPC RASA Black CPU Water Block // XSPC RS360 Radiator // XSPC X2O 750 Dual 5.25” Bay Reservoir Pump 2x Watercool Heatkiller GPU-X³ Hole Edition Waterblock Nickel/Black // 2x Watercool Heatkiller GPU-X³ Polished Backplate Corsair Vengeance K70 Keyboard // Corsair Vengeance M95 Mouse // Corsair Vengeance 1500 HeadsetCorsair Vengeance MM400 Compact Mouse Pad // Corsair Link Commander // Corsair Link Cooling and Lighting node
shogon
- Ribbons : 7
Friday, July 13, 2012 11:57 PM
Such a tiny little card, and little waterblock. Looks cool though, and those temps sound bout right. EK also lost my business with their new designs, good thing I got what I needed before hand.
I will either find a way, or make one. ٩(๏̯͡๏)۶
raw2dogmeat
- Ribbons : 7
Saturday, July 14, 2012 0:28 PM
loveha
I just about bought 2 of the Watercool blocks and backplates for my 670's today until I got to the part to pay..shipped would be $338.00 - ouch. Going to wait until they get to the states and see if they are any cheaper to buy local.
Cooler Master Cosmos SI7 4930K @ 4.4 GHz Asus Rampage IV Black 4 x 4 gb G.SKill - 2133 9-11-10-28-2T Corsair 1200w Sandisk Extreme II 240 gb (Windows 7, 64 bit) Velociraptor 1 tb (games) 980 Ti SLIXSPC Raystorm - XSPC Razer - EK Rampage IV Black Edition blocks
yapchagi
Saturday, July 14, 2012 1:30 AM
raw2dogmeat I just about bought 2 of the Watercool blocks and backplates for my 670's today until I got to the part to pay..shipped would be $338.00 - ouch. Going to wait until they get to the states and see if they are any cheaper to buy local. Shipping to US is too expensive right?
yapchagi
Saturday, July 14, 2012 1:37 AM
eternitykh with those temps, your pump is working correctly, your flow-meter is probably going bad. I tried tilting the pc case to see the waterflow back to the reservoir and it's really weak. I think I need a more powerful pump. I'm waiting for the EK-FC Bridge CSQ and install that first and see if the flow is still weak. If the flow is still weak, I'll get the Alphacool VPP655 1500 LPH pump. This is almost double the strength of my pump. Actually this is what I was afraid of....The epic fail design of the EK CSQ waterblocks ( too many 90-degree turns for the flow) ... it really hurts the waterflow. But the only reason why I bought EK waterblock is because it's the only waterblock for GTX 670 that's black. I'll probably get the EK-FC670 CSQ backplate as well as soon as it's available.
post edited by yapchagi - Saturday, July 14, 2012 1:47 AM
feniks
- Ribbons : 38
Friday, July 20, 2012 3:04 PM
so that EK block+plate combo is the only black one out here? kinda sucks, I don't like EK designs ... Heatkiller for gtx 680 looks kinda weird too with that aluminum colored backplate (only downside I can see) ... and no evga wb either, just a backplate for stock fan housing hmmmm ... kinda sucks ...
post edited by feniks - Friday, July 20, 2012 5:33 PM
yapchagi
Friday, July 20, 2012 4:52 PM
feniks so that EK block+plate combo is the only black one out here? kinda sucks, I don't like EK designs ... Heatkiller for gtx 670 looks kinda weird too with that aluminum colored backplate (only downside I can see) ... and no evga wb either, just a backplate for stock fan housing hmmmm ... kinda sucks ... yes, EK is the only one with black color waterblock for GTX 670. Others have weird colors on it. I really want it to be black.
feniks
- Ribbons : 38
yes, same here, I wanted a completely black block with black backplate, preferably the brushed black look kinda or something (have I just described an EVGA block + backplate? LOL!) ... well, the other blocks are looking weird, I agree on that I don't quite like that shape and backplate of EK block ... the Koolance for 680 looks much better IMHO, but it's still a steel/black combo, wondering if they keep the same theme for 670. I totally don't like the Heatkiller GPu X3 (again, for 680) block look either ... the backplate is OK, but it's all steel (no black) ... wondering when the rest of vendors finally releases them to market. I guess we have to wait and see.
yapchagi
Saturday, July 21, 2012 7:19 AM
feniks yes, same here, I wanted a completely black block with black backplate, preferably the brushed black look kinda or something (have I just described an EVGA block + backplate? LOL!) ... well, the other blocks are looking weird, I agree on that I don't quite like that shape and backplate of EK block ... the Koolance for 680 looks much better IMHO, but it's still a steel/black combo, wondering if they keep the same theme for 670. I totally don't like the Heatkiller GPu X3 (again, for 680) block look either ... the backplate is OK, but it's all steel (no black) ... wondering when the rest of vendors finally releases them to market. I guess we have to wait and see. performance-pcs said they should be getting the rest of the GTX 670 waterblocks too... the ones from Watercool and Aquacomputer.
raw2dogmeat
- Ribbons : 7
Saturday, July 21, 2012 11:48 AM
yapchagi feniks yes, same here, I wanted a completely black block with black backplate, preferably the brushed black look kinda or something (have I just described an EVGA block + backplate? LOL!) ... well, the other blocks are looking weird, I agree on that I don't quite like that shape and backplate of EK block ... the Koolance for 680 looks much better IMHO, but it's still a steel/black combo, wondering if they keep the same theme for 670. I totally don't like the Heatkiller GPu X3 (again, for 680) block look either ... the backplate is OK, but it's all steel (no black) ... wondering when the rest of vendors finally releases them to market. I guess we have to wait and see. performance-pcs said they should be getting the rest of the GTX 670 waterblocks too... the ones from Watercool and Aquacomputer. Thanks!! I'm going crazy waiting..overclocked my cards hit 70C in Crysis 2...EVGA still has no unlock available for the fan, so I don't know what else to do. I WANT MY WATER BLOCKS! haha
feniks
- Ribbons : 38
Saturday, July 21, 2012 6:48 PM
yup, I'm worried about the 72C thermal limit too as it causes a boost clock choke as I read... will see how it goes, I should be getting my first 670 reference in 2-3 weeks.
yapchagi
Saturday, July 21, 2012 10:41 PM
if anyone is getting the 670 waterblock + backplate other than EK, please post a picture of the card installed with the waterblock here. Would be great for us to see what it actually looks like. Maybe some results too. I'll update my picture/temp results as soon as I get the backplates.
feniks
- Ribbons : 38
Saturday, July 21, 2012 10:43 PM
^+1
pociej
Saturday, July 21, 2012 11:14 PM
feniks
- Ribbons : 38
Saturday, July 21, 2012 11:55 PM
^thanks, pociej! that's what I was afraid of. they kept the same theme for GTX 670 as for 680 cards ... I am not a fan of those colors ... worst things worst the steel backplate of Heatkiller GPU X3 doesn't look tragic in a totally black computer with red & blue leds ...
eternitykh
Sunday, July 22, 2012 0:19 PM
the 670 ref looks so cute with the heatkiller, hahahaha. but yeah that's the reason why i got the ftw so i can use 680 blocks, and for black computer with the polished backplate, i think it looks nice, it's like adding a trim to contrast. i used to use black ek block and plate on my 470, but i went with heatkiller this time because i like how the heatkiller backplate looks. i have a obsidian 700d with a sabertooth z77, black vengeance ram, but i like how the heatkiller's polished metal looks with it. i actually just ordered a second block + backplate, first one was from frozencpu, but they are sold out and haven't restocked since.... so i ordered from highflow.nl but it turns out it's on backorder... so i still gotta wait. im most likely gonna swap out to 2x 4gb ftw when it comes out, so i can still keep the blocks. i know it's a crap picture, too lazy to pull out my camera for now, but here was a picture when i was filling.
post edited by eternitykh - Sunday, July 22, 2012 0:28 PM
feniks
- Ribbons : 38
^cute it is. however I am glad I won't be seeing the front plate in daily use. HK's backplate is the nicest aftermarket one I've seen so far and I have to agree the polished steel contrasts quite well with the black background *sigh* ... where is the EVGA GTX 670 reference block + backplate? sure, more money involved, weaker design in details, but all in all the performance of their blocks is very comparable to best blocks and the look of EVGA equipment is top notch!
yapchagi
Sunday, July 22, 2012 6:05 AM
I don't like the colors at all on those aquagrafx and heatkiller blocks. At least EK still keeps the awesome black color theme even though they added those lame meaningless circles on it.
feniks
- Ribbons : 38
Sunday, July 22, 2012 6:13 AM
yapchagi I don't like the colors at all on those aquagrafx and heatkiller blocks. At least EK still keeps the awesome black color theme even though they added those lame meaningless circles on it. LOL, i'd rather go with a steel look of HK's backplate (still hate the front block looks though) than those stupid circles on the black backplate of EK ... kinda reminds me of cheap rubber anti-slippery mat in some workshop toilet (no offense, it's my personal impression) ...
post edited by feniks - Sunday, July 22, 2012 6:41 AM
feniks
- Ribbons : 38
Sunday, July 22, 2012 6:36 AM
this is the 680 Koolance block (it looks best so far among aftermarket IMHO), I'm pretty sure they will keep the same theme for reference 670 block: and at least for reference 680, people can use an EVGA backplate: http://forums.evga.com...?m=1557818&mpage=1 I failed to find Koolance backplates ... ... anyways there is no EVGA GTX 670 backplates yet that would fit after stock housing removal ... those listed in EVGA stroe are for stock air cooling (fan housing extends the card length): I am pretty sad right now ... no options for good looking decent water cooling block and cool looking backplate on reference GTX 670 ...
eternitykh
Sunday, July 22, 2012 7:54 AM
custom :D dremal the evga backplate and use it with your waterblock oh and i have the hole edition, nickel plated and the "hole" plate is black like so (another crappy picture i know) or here the official picture:
post edited by eternitykh - Sunday, July 22, 2012 7:57 AM
feniks
- Ribbons : 38
^ trust me I am very close to doing so  (after I get the backplate that is) ha ha! and I'd probably go with Koolance 670 reference block once it gets released ... pity that Koolance doesn't make matching back plates ....
eternitykh
Sunday, July 22, 2012 7:58 AM
yeah..... i wonder why koolance dont make backplates :/ im sure people that buy their blocks would love to get a matching set of backplate with them...
yapchagi
Sunday, July 22, 2012 10:02 AM
I thought koolance said they won't be making a waterblock for GTX 670.
feniks
- Ribbons : 38
Sunday, July 22, 2012 6:34 PM
yapchagi I thought koolance said they won't be making a waterblock for GTX 670. for real? do you have a link to source? it was the best looking block so far ...
raw2dogmeat
- Ribbons : 7
Sunday, July 22, 2012 8:44 PM
