replacement modular cables for NEX750B
__adrian
2016/11/15 08:29:08 (permalink)
Does EVGA provide replacement modular cables for the Supernova NEX750B?  Just stock cables, not individually sleeved or anything fancy.  In fact, I only need one, for sata power.
Secondary question:  does anyone know the pinouts for the sata cable for this psu?  I have a few modular cables from other PSUs but I think they're wired differently.
Thanks!
3 Replies Related Threads
    bob16314
    • Ribbons : 203
    Re: replacement modular cables for NEX750B 2016/11/15 11:21:17 (permalink)
    Welcome to the forums.
    1. Not that I know of..Using something like a widely available SATA Power Y-Splitter that makes two SATA power connectors from one won't work for you?
    2. Yes, they may be (and often are) proprietary/wired differently at the PSU end..SATA power pinout on the component end can be found here..Pinout at the PSU end would need to come from EVGA..You can measure the voltage and remove the terminals and switch them around to the proper locations if necessary..Component end pinout is industry standard..There is no industry standard PSU end pinout, they can be different.
    * Cooler Master NV-334 * ASUS P8Z77-V LE PLUS * Intel i7-2600K @ 5.0GHz * Corsair H80 * Seasonic M12II 750W * 4x4GB 2133MHz Patriot Viper Xtreme * EVGA GTX 760 SC * 2 x WD 500GB Caviar Black RAID 0 * Toshiba DT01ACA 500GB * Dual-boot Win7 Home Premium 64-bit/Win10 Home 64-bit *
    "If it ain't broke, fix it untill it is"
    __adrian
    Re: replacement modular cables for NEX750B 2016/11/15 11:27:04 (permalink)
    > SATA Power Y-Splitter …won't work for you?
    Sorry, I was unclear. I don't have any of the modular cables for this PSU in the first place.  The only modular cables I have are from other (brands of) PSU's.
    This is what I suspected.
    Well, could if I had a multimeter.  : )
    But yes, switching around the terminals is why I was looking for the pinout arrangement.
    Thanks very much!
    post edited by __adrian - 2016/11/15 11:30:38
    bob16314
    • Ribbons : 203
    Re: replacement modular cables for NEX750B 2016/11/15 13:22:52 (permalink)
    Well, I guess if all else fails and your other cables fit into the 750B you can hotwire the 750B and check the pinout voltages and rearrange the terminals if neccessary kinda like I said in post #2 here and make your own pinout diagram for the 750B..Some multimeters are dirt cheap..You can find practically all component end pinouts here..That's about all I can tell you..Good luck.
