trying to fully stabilize and balance my overclock on new GTX 670 reference card. learned the limits of max boosted core and memory alone and then combined them together sacrificing little on both front lines to make it stable ... however one problem left ... the actual TDP as per GPU-Z goes well over the max TDP limit (Power Target of 122% in Precision X) and once it goes over 128% the card starts throttling down in 13MHz increments when under full load ... so far it seems that the only "soft" solution is to lower the core & mem clocks togetheruntil the card no longer goes too much over max Power Target under full load ... and so settling for a lower (firm though) overclock... is there any way to fix this problem? what I mean is, EVGA, any GPU BIOS updates for that or it's gonna stay locked like this effectively limiting the maximum (stable) overclocks? a little disappointing.
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." - Aristotle
Re:overclocking GTX 670 reference ... hitting over TDP limit and power throttling under lo
2012/08/09 10:33:33
Sorry not possible to adjust. Remember that this varies depending on application also.
jfreeZr - [rebuilding] 4770k @ 5.2ghz || evga z87 classified || 2x evga gtx 980 acx2 || 16gb 2.6ghz ddr3 || 500gb 840 evo raid0 || evga supernova 1000 P2 hadronGTX - 4770k @ 4.4ghz || evga z9 stinger || evga gtx780 ti acx || 16GB 2.6ghz ddr3 || 480gb vertex3 raid0 || 500w gold
cwinot
2012/08/09 10:45:33
My 670SC 4GB also goes over the power target of 122%, I have seen mine go as high as 130%, haven't had it throttle down because of that though.
Motherboard: ASUS Sabertooth Z77 CPU: Intel i5 3570k - OC to 4.5ghz CPU cooler: Zalman CNPS9900MaxB GPU: EVGA GTX 670 SC 4GB RAM: Crucial Ballistix Tactical Tracer 1600 - 16GB (4 x 4) PSU: Thermaltake Black Widow TR2 RX 850w HDD: Seagate Barracuda 1TB 7200rpm ODD: HP dvd1260i Case: Rosewill Challenger
2012/08/09 11:19:57
EVGA_JacobF Sorry not possible to adjust. Remember that this varies depending on application also. thanks for chiming in. ehh, that's what I was afraid of, pity it cannot get even slightly increased, let's say extra 10% of headroom ... yup, I noticed that different apps (e.g. Heaven 3.0 vs 3dmark11 vs ScannerX) create different load and while in Heaven 3.0 the card completes at 120% max TDP, the 3DMark11 causes the same overclock's TDP to spike up to 130% ... I can imagine it gets even worse with games like BF3 or something like Metro 2033 at full settings ... I actually found a quicker way to check the max actual TDP under load, EVGA Scanner X in full screen Tessy mode and max quality options does it too in a matter of seconds instead of minutes while benchmarking with 3dm11.
post edited by feniks - 2012/08/09 11:31:31
2012/08/09 11:29:53
cwinot My 670SC 4GB also goes over the power target of 122%, I have seen mine go as high as 130%, haven't had it throttle down because of that though. I can assure you that it does throttle down, but since increments are tiny (13MHz each time, but it can do it several times within a second) you will not notice them on Precision X graphs until you limit MIN to 980 and MAX to like 1300 and set polling interval to 500ms, then you can see it under full load. other way to notice it is to watch carefully the Precision OSD with current Core clock during benchmark/test and see how it jumps back and down using multiple of 13MHz increments. with the TDP high enough over limit it can drop e.g. 13, 26 (2x 13MHz) or 39Mhz (3x 13MHz) sometimes even if overclock is "normally" stable. I am running 304.79 driver now if it matters, but I don't think this TDP thing is a driver programmable item, looks like a part of GPU BIOS programming most likely.
cwinot
2012/08/09 11:53:47
feniks cwinot My 670SC 4GB also goes over the power target of 122%, I have seen mine go as high as 130%, haven't had it throttle down because of that though. I can assure you that it does throttle down, but since increments are tiny (13MHz each time, but it can do it several times within a second) you will not notice them on Precision X graphs until you limit MIN to 980 and MAX to like 1300 and set polling interval to 500ms, then you can see it under full load. other way to notice it is to watch carefully the Precision OSD with current Core clock during benchmark/test and see how it jumps back and down using multiple of 13MHz increments. with the TDP high enough over limit it can drop e.g. 13, 26 (2x 13MHz) or 39Mhz (3x 13MHz) sometimes even if overclock is "normally" stable. I am running 304.79 driver now if it matters, but I don't think this TDP thing is a driver programmable item, looks like a part of GPU BIOS programming most likely. Not saying I don't believe you I am sure you have more knowledge than me. I have adjusted my overclock a bit since then (122%,+75core,+210mem now) when my power target was spiking to 130%. Now it only spikes up to 128% (not very often though) and I have never seen it dip below 1228mhz in the OSD while playing BF3. I will set my Precicsion graph limits to what you suggest and check it out when I have a few minutes later. I am on the 304.48 beta driver if that means anything.
2012/08/09 12:01:01
no probs, 600 cards are new to me, I am still learning where the limiting walls are ... on my 670 I can run +149core/+564mem (actual 1246core/3571mem) with only tiny clock throttling issues (oscillation) whenever the TDP goes overboard by too much. so far used it only for benchmarking though, now looking for something more solid for daily running and gaming ... for now decided to lower both the core & mem offsets together until I find settings that do not get throttled by Power Target of 122%.
cwinot
2012/08/09 12:08:46
Why can these cards even go over the power target that you set in Precision anyhow? I would think if you set a limit on it, shouldn't it stay under that limit, otherwise why even have one? I just don't understand these new cards yet either, I do like them though, great performance! I will figure them out eventually I hope!
2012/08/09 12:11:13
^ha ha! I am wondering about the same things LOL!
cwinot
2012/08/09 12:15:55
Yeah I had a much easier time squeezing every bit of performance I could from my 560SC 2GB card, it seems that these new 600 series cards have a mind of their own sometimes!
2012/08/09 12:16:59
cwinot Yeah I had a much easier time squeezing every bit of performance I could from my 560SC 2GB card, it seems that these new 600 series cards have a mind of their own sometimes! +1 exactly he he
cwinot
2012/08/09 15:14:18
Just got done playing some BF3. I setup my GPU clock graph in Precision X how you suggested and even though my power target spiked up to 129% it never down clocked on me, a solid 1228mhz the whole time.
2012/08/09 15:41:55
interesting. thanks for input. for me it was visible. However I think I may have goofed a bit. namely I have just discovered I forgot to disable vsync and adaptive power mode in nvidia settings ha ha! will double check with my GPU OC and ScannerX (fastest to generate such a load to cause TDP spike).
2012/08/09 15:46:01
no dice. it still does it, just dropped 13MHz under Scanner X tessy load within 10 seconds. max TDP registered in gpu-z shows 128.1% I guess it's time for me to lower the clocks and find where the core stops getting throttled.
2012/08/09 16:15:44
all right, it's officially pissing me off now ha ha! I lowered the clocks severely and it is still happening... I know it's just a stupid 13MHz drop but I don't like it. Perhaps I should just get used to it ... I re-adjusted graphs of Power (min 105, max 135) and Core (min 1150, max 1250) and altered polling to 250ms, this is what I am talking about:  Uploaded with ImageShack.us Not a real problem I guess (13Mhz can't hurt LOL!), just a Keppler annoyance ... perhaps best to left ignored ...
2012/08/09 16:59:48
jumped a few steps down and found a spot where it does NOT do this anymore, not a borderline probably as the TDP spikes up to 126.2% and given the specs (122 + 7% variation = 130.5%) it could be below the border. from previous observations, I think it starts doing the 13MHz power throttling when it hits above 128% TDP. Uploaded with ImageShack.us EDIT: found the border of power throttling vs no throttling under load to be around those numbers: a) without power throttling, TDP max 127.5% (under ScannerX-tessy-max) or 115% under heaven3.0, set values were 122%, +110core/+364mem (actual 1202MHz/3370) b) with power throttling, TDP max 129% (under ScannerX-tessy-max), set values were 122%, +115core/+364mem (actual 1215/3370) not sure what to think of it at all ... c) maximum stable with power throttling, TDP max 132%(didn't check under ScannerX-tessy-max), +149/+564 (1246core/3571mem)
post edited by feniks - 2012/08/09 17:44:14
cwinot
2012/08/09 18:07:57
Not sure why I am not seeing it do this with my card, I will take a little more time to check it out tomorrow. Maybe it depends on the card you get, some throttle sooner than others.  Some good info though.
2012/08/09 18:15:37
idk, the power throttle threshold depends solely on the stregth of stress testing app you use. I just realized that what was stable (against Power Throttle) under ScannerX and heaven3.0 is NOT any longer "safe" against the 3dmark11 bench (Test#1 is enough)... went as low as +100core/+314mem and the TDP related throttle was still happening ... for now I ignore it and use a high stable OC and see what it gives (perhaps nothing ever).
cwinot
2012/08/09 18:36:25
I use BF3 as my stress tester for the most part, after my overclock passes Heaven and 3dmark11 benches. I backed my overclock down a tiny bit (-5mhz) because I was getting some crazy artifacts in BF3 but no problems running through the benches. Haven't had any trouble since, only time will tell though, it was fine for a while with my previous settings then I saw this. [image]<a href=" alt="" /><img src="http://i1271.photobucket.com/albums/jj638/91xcab/bf3_2012_08_06_17_23_31_034.jpg[/image]" _mce_src="http://forums.evga.com/null" />
cwinot
2012/08/09 18:39:18
Hmmmmm...... not sure why my pic isn't showing up? There got it. Looks good huh? (Sorry this really has nothing to do with the power throttling, I just had to show these to someone).
post edited by cwinot - 2012/08/09 19:02:15
maniacvvv
- Ribbons : 159
2012/08/09 21:01:02
cwinot Hmmmmm...... not sure why my pic isn't showing up? There got it. Looks good huh? (Sorry this really has nothing to do with the power throttling, I just had to show these to someone).  Your video memory OC is way out of bounds I dont understand you guys.... Why do you think overclocking Vram will give you any real gains in games? They dont Memory clocks provide -nothing- compared to core clocks for increasing framerates. All overclocking memory on 600 series does, is increase the total wattage and -decrease- you ability to reach higher core speeds. Look at the pics above, was that really worth the whole 1.5fps performance increase with a 400mhz increase If you want the best performance in game (highest framerates), leave the memory at stock and work on the core alone
post edited by maniacvvv - 2012/08/09 21:05:37
2012/08/09 21:10:48
when OC'ing the core alone I can do +155MHz (1252MHz) with memory stock while I can bump memory +564MHz by sacrificing only 6MHz on the core max boost ... pretty good deal if you ask me
2012/08/09 21:46:19
re-flashed the 670 with new updated bios (improving stability), so far so good , the last stable OC went through 3dmark11 on automatic voltage. I also see that TDP management has gotten more aggressive ... max TDP reported is now lower (126.5% max vs around 132% before the update at same settings) ... however the card power throttles even more now, dropping sometimes (especially in Test#1 of 3Dmark11) as much as 143MHz on the core when running max boost of 1243core/3524mem ... the funny part is that now it does that even at lower TDP limit than before ... and it's different even in graphs Uploaded with ImageShack.us also, not sure how, but I noticed that Adaptive Vsync gives me better 3dmark11 score, by over 100 points ... hmmmm ....
post edited by feniks - 2012/08/10 07:29:57
cwinot
2012/08/10 06:26:51
2012/08/10 09:21:09
OK, so it's simple. the power throttling under load (when OC'ed) is a part of mechanism implemented to prevent the TDP from going overboard. with new GPU BIOS the power throttling is even more aggressive now, but in return the TDP stays within 7% of Power Target (Improving stability of OC). I guess that's an acceptable compromise.
