That is a sweet set-up, very nice looking. Did you customize the GPU backplate or did it come that way?
NukerCharlie, you can't post link's until you get a few more posts. It's set up that way for spammers unfortunately.
You should make a mods rig profile, with a 3dmark score. This enters you into a drawing after so many systems are entered, and also people can see your handy work. A winner will be drawn after 19 more systems are shown.
http://www.modsrigs.com/toprating.aspx
