ilyama
Re: first test of EVGA's 1070 1080 FTW Fix: Thermal Pads and MAKE THE CARD TWICE AS LOUD?
2016/11/09 06:34:07
80% of fan for 65 degres ? What was the game ?
nycalex80
2016/11/09 07:02:59
ilyama 80% of fan for 65 degres ? What was the game ?
usually on low demanding games: all games run on all settings ultra @ 2560x1440 @ 144hz refresh -dota 2 fans around 70-80% fan, 60~65 degrees. -street fighter 4 and 5 same as above -starcraft 2 same as above now for more demanding games: -overwatch = fans at 100% (extremelly loud) 69 degrees constant -cod infinite warfare = same as above, but temp seems to rise slightly to 70~72 -battefield 1 same as cod -mafia 3 same
Be Quiet! Dark Base Pro 900 orange edition Asus ROG maximus viii hero I7 6700k @ 4.5 1.32v Corsair H115i cooler with 4 x noctua nf14 fans, push/pull. 32gb Gskill trident Z Evga supernova P2 1000w Evga gaming acx GTX 1080 500 gb samsung 960 Pro nvme ssd 240gb samsung 840 pro 500gb samsung 850evo x 3 Hitachi X300 6tb HDD LG blueray burner/player absolutelly ZERO cable management (i'm too lazy)
2016/11/09 09:26:11
nycalex80 just did bios update on my card yesterday. temps down from 80 to 65~69. i'm happy with this. however............ holy smokes is it LOUD??????? it is significantly loud at the moment, up to the point that it's actually pissing me off. reminds me of my old R9 fury, straight up jet engine on takeoff. needless to say, i am VASTLY dissapointed. yes they fixed the temp problem, but the decibel levels of the fans are ridiculous. i've spent over $150 on fans to both cool and be QUIET at the same time. that's 6 x noctua nf-a14 fans at $25 a pop. But it all went down the drain since the gpu is generating an insane amount of noise when fans go above 80% (which is 100% of the time while gaming)
Are you using afterburner or precision x?
If you would like to use an affiliate code to register a product, feel free use this one: >Click Here< This is not my affiliate code! This is a random users code. This code will change often, and you will never be told who it belongs to! If you would like the possibility of your code being listed above, it must be in your signature block. I will not take requests to use a specific code.
nycalex80
2016/11/09 09:28:16
Scarlet-Tech
precision xoc for a 2050mhz oc. but even if i don't oc at all, the fans still go as loud as if i'm oc'ing. the temps do drop about 3-5 degrees when not ocing, but the fans still spin very loud
2016/11/09 09:33:24
nycalex80
Turn precision off. The bios is set to run fan speeds approximately 10-15% higher than it was previously. Using precision and setting it so high is a user setting. You can also turn the fans down a little. If you were using an aggresive fan curve, the bios doesnt change much other than adding a chance for a higher fan speed. You just need adequate airflow, not turbines.
post edited by Scarlet-Tech - 2016/11/09 09:37:41
Athena
2016/11/09 09:53:33
I for one do not do "normal gaming" Fallout 4 at max with Mods and GTA 5 online max as well. I did not buy my card not to use it or to have it loud when I could have spent 10 bucks more for MSI Hopefully the RMA'd card will not have the problems people are talking about or I will be very sad and feel burned.
seahawkgfx
2016/11/09 10:03:58
The RMA´ed card will use the same BIOS. Scarlet-Tech
nycalex80
Would it not be possible to finally put some more specific data into the main thread? We have heard 2200rpm, 2000rpm, 200-500 rpms more, 10-15% more. This all does not match at all. My 1080 ACX 3.0 (non SC) runs Heaven at around 1300 rpm, going to 1450 rpm would be fine, going to 1500 rpm is fine, going to 1700 rpm is clealry more audible than before, going to 2000rpm is unacceptable.
post edited by seahawkgfx - 2016/11/09 10:07:59
nycalex80
2016/11/09 10:39:48
Scarlet-Tech
nycalex80
i supposed i could do that. but then, what was the point of me spending $649 for a card i cannot use to it's FULLEST potential? one of the main attrractions of a custom cooler, is to squeeze a tiny bit more performance out of it. by the way, i did turn off precision xoc comepletelly while defaulting the speed prior to removing precision xoc. still LOUD as hell.
dyceskynes
2016/11/09 12:24:53
Adjust the fan curve to meet your sound / cooling requirements. That is what it is there for.
Intel Core I7 3930K @ 4.5 | 16GB Corsair Vengence 1600 MHZ | EVGA X79 Dark | EVGA 1080 FTW | 256GB 850 Evo SSD x1 | 500 GB WD x2 | EVGA 1000 G2 | XSPC Raystorm, 360 + 180 Rad, MCP655 | Win 10 Pro
nycalex80
2016/11/09 12:33:17
dyceskynes Adjust the fan curve to meet your sound / cooling requirements. That is what it is there for.
acceptable sound levels means that i have to get the temps into the 80's. i posted this as soon as i bought the card, since it was strange that the card would operate at such high temps: http://forums.evga.com/GT...ng-Temps-m2511663.aspx
2016/11/09 12:36:13
seahawkgfx Would it not be possible to finally put some more specific data into the main thread? We have heard 2200rpm, 2000rpm, 200-500 rpms more, 10-15% more. This all does not match at all. My 1080 ACX 3.0 (non SC) runs Heaven at around 1300 rpm, going to 1450 rpm would be fine, going to 1500 rpm is fine, going to 1700 rpm is clealry more audible than before, going to 2000rpm is unacceptable.
If you want me to provide more specific data, i can not. I do not work for evga and have no more specific data than you have been provided. nycalex80 i supposed i could do that. but then, what was the point of me spending $649 for a card i cannot use to it's FULLEST potential? one of the main attrractions of a custom cooler, is to squeeze a tiny bit more performance out of it. by the way, i did turn off precision xoc comepletelly while defaulting the speed prior to removing precision xoc. still LOUD as hell.
Run your card to full potential, turn the fan down. It used to run at a set fan speed. We will say 1600rpm. If you had previoudly set it to 80% and it ran at 1600, adjust the percentage down to that speed now. Its a very simple concept. At 55%, my card remains silent on an open bench. If you are setting it to 80% inside the case, adjust the fans lower. You can also retry the thermal paste on the core as well. That usually lowers temps a little as well.
post edited by Scarlet-Tech - 2016/11/09 12:38:21
seahawkgfx
2016/11/09 22:00:44
Thanks for the reply, I was hoping a EVGA tech could supply more data.
Dark Chronos
2016/11/09 22:26:43
Troyhe98 The point being...one of the deciding factors on purchasing these cards was because they were the quietest cards on the market (besides something on water block). The other issue I am concerned with is the potential decrease in resale value after this mess.
"potential" decrease in resale value? AHAHHAHAHAH
seahawkgfx
2016/11/10 10:50:11
I run my own test: So I tested the new BIOS for the 1080 ACX 3.0 and I think this is not acceptable. Running Heaven the fans spun at ~1250rpm at 20°C room temperature, with the new BIOS they go up to 2050rpm. This is clearly audible when not using headphones. 800rpm more is way too much imho. I went back to the original BIOS and will wait for the thermalmod pads to arrive.
NeroRay
2016/11/10 10:53:52
People who claim the card didnt get louder after the new bios update are either lying or deaf
Sean1976
2016/11/10 12:10:25
This is where I say "Im so glad I stuck with reference design 1080GTX"! Haven't heard the fan on my 1080 GTX F|E to date, nor has it broke 64C to date!
Intel i5 4690K Devils Canyon@ 4.7Ghz @ 1.320Vcore Asus Sabertooth Mark 2 Z97 deck Hyper 212 Evo Air After-Cooler Evga 1080 GTX Founder's Edition@ 1987mhz core/5400mhz memory G-Skill Sniper 1866mhz memory 9-10-9-28 CAS latency(16GB)2x8GB sticks 1x Intel 540 series SSD 480GB 2x Intel 520 series SSD 240GB each(480GB) 2x Intel 535 series SSD 240GB each(480GB) Corsair HX850 Watt Gold Psu Antec Eleven Hundred v2 Carbon Fiber case w/ 9x 120mm fans BenQ XL2420TE 144hz 1ms Lightboost/MotionBlur/ Gaming panel(1080p)TN G15/G9 Logitech gear http://www.3dmark.com/3dm/12966736?
dagiccross
2016/11/14 11:32:44
So disappointed, been researching the Internet making sure I will buy the right GPU, turns out I'm dealing with their mess and It runs as loud as a stock price GPU. Not sure if I will purchase another EVGA products again
boltaction
2016/11/14 13:34:19
EVGA_JacobF That was an early solution before finalized, but the final is around 2000 RPM during Furmark (normal gaming will be lower). During Furmark it is necessary for the fans to spin at 2000RPM. Normal gaming will be quite a bit lower.
Part Number: 08G-P4-6181-KR Part Desc: EVGA GeForce GTX 1080 GAMING ACX 3.0 Mine runs over 2200 all the time playing Call Of Duty Modern Warfare remastered. It's like a jet engine, very noticable.
boltaction
2016/11/14 13:37:09
Can someone point me in the right direction for the original bios for Part Number: 08G-P4-6181-KR Part Desc: EVGA GeForce GTX 1080 GAMING ACX 3.0 because I'm getting tired of this crap
