Circaflex
I originally sent my e760 in to have the Turbo mod completed. Evga sent me a new board. Upon trying this new board it would power on fans spin then shut off. I resent that board in and got another one problem is this ones doing the same thing. Had no issues with original board. I'm going to swap cpus to see if that's the issue but if it still does this I'm lost as everything was fine. I don't want to have to email another board and waste evgas time or mine. What's the most common cause for this?
loveha
- Ribbons : 53
Re:e760 power on power off cycle
2011/09/28 14:42:35
Does it start up at all? Or it just goes through the same cycle of start up, shutdown, start up, shutdown.
Case: Corsair 900DMotherboard: EVGA Z170 Classified E179CPU: Intel Core i7 6700K 4.6GHzRAM: 16GB Corsair DDR4 2133 16-15-15-36GPU: EVGA GTX 1070 FTW DT SLIPSU: EVGA 1000w G2SSD: Samsung 512GB 950 Pro NVME M.2Monitor: Acer Predator X34 100Hz G-SyncSound: Schiit Modi 2 DAC~Schiit Vali 2 AmpHeadphones: AKG K7XX Massdrop Edition
KMoore4318
Pistoj Doulos Unum Pluribus
- Ribbons : 233
2011/09/28 18:39:21
Make sure you are giving it enough time, the first post on a new board should shut down after it detects a change from what it was set up as during manufacturing, it may take up to a minute or two, for it to read the new settings, purge the old settings , write the new settings and then reboot. The first time you power up, should take longer than any other boot. I usually put it, in power up, and then go get a coffee of beer, come back sometime latter and see what is on the screen.
post edited by KMoore4318 - 2011/09/28 18:41:48
Just clink Link to Register > My Affiliate Code:VTJPDC4OMB 1)965 V-8 E758(77)580 AX1200 2)980 NH-U12P-SE E761(77)2(980) AX1200 3)980X H-70 E770 (77)2(590) AX1200 4)980X H-70 E762(77)2(580) AX1200 5)920 EVGA Super Cooler E756(82)590 HX1000 6)680I 2(560-ti) HX1000W
Circaflex
2011/09/29 08:55:02
It never fully POSTS, fans spin for a few seconds, codes go through on the board and it restarts. here is a video of what it does <iframe width="425" height="349" src="http://www.youtube.com/embed/2WAjOFCudwg?hl=en&fs=1" frameborder="0" allowfullscreen></iframe> if that doesn't work here is a link youtube. com/watch?v=2WAjOFCudwg be sure to remove the space between .com
kram36
- Ribbons : 46
2011/09/29 09:41:04
Looks like a dead cpu to me.
KMoore4318
- Ribbons : 233
2011/09/29 09:43:41
either your psu is shot, or something is pulling a leg out of specification, or the CPU is not regestering the voltage presant. Pull as much as possable, see if it boots minimum configuration. if so add componants one at a time until it fails again. if not consider pulling it from the case and booting on a non conductive surface. EVGA may have additional recomendations 1-888-881-EVGA (3842) disregard the error codes, your not on long enough for them to be of any use.
post edited by KMoore4318 - 2011/09/29 09:46:23
Circaflex
2011/09/29 09:50:03
if i pull the CPU will the board still boot but just say no cpu installed? edit: I pulled the cpu and fired up the rig it stays on now and doesn't do the start up shut down, safe to say CPU? Did i do any harm turning it on without a CPU?
post edited by Circaflex - 2011/09/29 10:12:26
kram36
- Ribbons : 46
2011/09/29 10:13:38
Circaflex if i pull the CPU will the board still boot but just say no cpu installed? I don't know, I've never tried that. This is exactly what two EVGA boards I tested a dead cpu in did.
Circaflex
2011/09/29 10:13:59
KMoore4318 either your psu is shot, or something is pulling a leg out of specification, or the CPU is not regestering the voltage presant. Pull as much as possable, see if it boots minimum configuration. if so add componants one at a time until it fails again. if not consider pulling it from the case and booting on a non conductive surface. EVGA may have additional recomendations 1-888-881-EVGA (3842) disregard the error codes, your not on long enough for them to be of any use. I tried with only gpu having extra power, left all HDDs and cd rome off still no boot. Case is an acrylic board with rubber standoffs.
kram36
- Ribbons : 46
2011/09/29 10:59:02
You said in your opening post you have another cpu. Give it a try.
HalloweenWeed
- Ribbons : 36
2011/09/30 06:27:30
Circaflex Did i do any harm turning it on without a CPU? No, ppls have done this in the past when they were too impatient to wait for the CPU; and panicked when it acted like that. Installed CPU and all was fine. It does sound like a bad CPU, but impossible to tell for sure. GL.
Main (gaming) rig: i7-3930K; Asus Rampage IV Extreme; H100 W/p-p Excaliburs, AS5; MSI 7870 2GD5/OC; Crucial M4 SSD 256GB. See my primary ModsRigs: Adam for the rest, and I have a second (wife's) rig Asus Rampage III Extreme & 960: Eve. Overclocking is useless to me if it is not rock stable.
Circaflex
2011/10/01 17:57:05
So just an update, i tried a known working 920 does same thing, tried with a processor i purchased today same thing. Guessing another board? i hope evga pays for shipping this time, this sucks because the board i sent out originally for the turbo mod was great, first board back does this and so does the second. I even tried with a different known working PSU same issue :(
Circaflex
2011/10/04 15:04:30
do you guys believe this is a board issue? Without a CPU it stays on but obviously nothing happens, with a CPU on/of cycle. Im buying another PSU just to test but i know this one is current and working
kram36
- Ribbons : 46
2011/10/11 17:21:33
Which memory slots are you using? You should have the memory in the red slots for the first 3 sticks.
Circaflex
2011/10/12 15:05:58
i have 3 sticks in the black slots, ill give that a try here is my run down that i sent evga as i submitted another rma ticket I tried isolating a short issue by moving to an acrylic case, and even using the motherboard boxI purchased a new power supply to ensure it was not a power issueI purchased a different i7, 920 processor to test and ensure it was not a CPU issueI purchased new corsair memory and same thingI tried with 1 5870 and even with a 8800gt from a working computer still not working
HalloweenWeed
- Ribbons : 36
2011/10/12 15:09:06
The manual clearly says:  so if you are using the black slots it's your mistake.
Circaflex
2011/10/12 15:23:18
i feel like a total noob, system boots fine now :( sorry for wasting anyones time, especially evga's
HalloweenWeed
- Ribbons : 36
2011/10/12 15:32:48
It's a valuable lesson to learn, makes you more experienced and knowledgeable, it only makes you better for next time. We all need a humbling lesson every once in a while, it even happens to me - more often than I would like! Not wasted time, happy to have helped you.  Now if I didn't help, then that would be wasted time.
Circaflex
2011/10/12 15:59:14
now time to see how far i can go under some phase ;)
kram36
- Ribbons : 46
2011/10/12 16:57:48
Circaflex i feel like a total noob, system boots fine now :( sorry for wasting anyones time, especially evga's Just dawned on me yesterday about the memory slots. I sold a board to a member here a couple months ago and he sent it back to me saying it wouldn't boot, doing the power cycle like your vid. I got the motherboard back and noticed he was using the wrong memory slots as he left the tabs open on them. Sorry about that. I totally forgot about that deal, wish I would have thought about it sooner. Glad you're up and running now.
HalloweenWeed
- Ribbons : 36
2011/10/12 18:00:48
Good catch, Kram! Belated or not.
